Going to look at a YJ tomorrow.. any advice? - JeepForum.com
post #1 of 6 Old 09-04-2011, 05:38 PM Thread Starter
ajamison
ajamison's Avatar
1991 MJ Comanche
I'm going to look at a '94 6cyl 5 spd tomorrow.. I had a YJ back in high school when I didnt know anything about jeeps so i don't remember much. Is there anything I need to pay careful attention to when looking over the jeep? clearly body and frame rust are a concern. The windshield frame probably needs replaced due to rust, but the seller says everything else has the "typical rust for a jeep of its age". I dont mind repairing rust spots. So is there anything else I need to keep an eye out for? By the way, the jeep has a 4" lift and 35s... Any advice or links would be greatly appreciated! Thanks
Jamison
ajamison is offline
post #2 of 6 Old 09-04-2011, 06:05 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Watch for Rust on the frame around the rear shackle mounts !
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 6 Old 09-04-2011, 06:19 PM
nembudonna
Keep your eyes open and your wallet shut.
nembudonna is offline
post #4 of 6 Old 09-04-2011, 08:09 PM
USMC3531
How many miles are on it? Watch for blue smoke out of the exhaust when you rev it up. I'd pull the plugs to get a look at them if the guy will let you. They should be tan and not black with wet oil. Check the oil dipstick for signs of water (the oil will look like mud). Does the engine run smoothly? Check to be sure the 4 wheel drive is actuating, not just shifting into low range (the 4 wheel drive light should be on). Drive it and check for unusual sounds, does the trans shift smoothly, or pop out of gear. Look around under the motor for oil leaks. Look under the radiator for water leaks. Are the hoses and belts good? Are there any squeals from the water pump or alternator? Are the shocks and steering stabilizer in good shape? Take a look at the front disc rotors, are they smooth? How are the tires?
This could go on and on, but that's what I'd look for, besides the rust.
USMC3531 is offline
post #5 of 6 Old 09-04-2011, 08:21 PM
Firefyter-Emt
Rot at the frame, both the very end near the shackle mount, and near the front hanger for the rear spring. I hear they can rot near the steering box too, but I have not seen one.
Rot at the floor boards, in the front around the brace that goes down to the floor and behind the seat around the seat belt and roll bar. Also look underneath for rot at the braces on the floor.
Open up the air cleaner and look for either a new filter, or signs of oil. These like to have "blow by" and the breather hose should go into the top of the air cleaner from the PCV valve. (Make sure it does too!)
Look under the carpet to see if the drain plugs are all out, this could be signs of a bad water leak. Also, peek under the dash to see if there are signs of heavy corrosion that could point to a water leak as well.
Try the 4WD and see if it feels like the front axle in engaged. It should bind and buck a little with the wheel cut. If not, you may need work on the front axle disconnect.
Check all the gauges, they have ground issues and you could have some that are not working. Is it on empty? That could be a dead gauge.
As mentioned above, check for the normal "used car" stuff like leaks and condition.
Firefyter-Emt is offline
post #6 of 6 Old 09-04-2011, 09:22 PM Thread Starter
ajamison
ajamison's Avatar
1991 MJ Comanche
thanks for the replys fellas! its got 25k on the motor and over 250k on the body.. im expecting rust, but at least now i know where to look
Jamison
ajamison is offline
New guy here going off road for first time tomorrow... any advice? paulgraff Wrangler General Discussion 14 05-04-2010 09:57 AM
Herculining tomorrow and need some advice. JeeperCane YJ Wrangler Technical Forum 7 08-02-2008 12:47 PM
Looking to buy an 89 YJ tomorrow and could use some advice joburnet YJ Wrangler Technical Forum 5 01-25-2006 03:12 PM
Ordering tomorrow, need final advice Baze YJ Wrangler Technical Forum 19 10-05-2004 11:45 AM
Need advice ! buying a YJ tomorrow sector YJ Wrangler Technical Forum 13 08-20-2004 09:30 PM
