Going into gear - JeepForum.com
post #1 of 8 Old 09-12-2013, 07:22 PM Thread Starter
the_hub49
Going into gear
Ive noticed my jeep likes to grind going into third sometimes, along with first and second less often. Is this due to there not being enough tranny fluid or the tranny its self. The unit is all stock. Ive been really easing to the gears to see that made a diff but no luck. Some 2 cents would help
the_hub49 is offline
post #2 of 8 Old 09-12-2013, 08:13 PM
atldude
You can check the oil level in tranny. Check also your clutch mc for leaks and proper fluid level. On firewall under hood and in cabin and down at tranny. If everything ok then probably synchros like mine .. Been driving it forever like that just been careful and upshifting earlier.
atldude is offline
post #3 of 8 Old 09-12-2013, 10:17 PM
jokerchief462
Have you changed the trans fluid lately. Try some syncromesh synthetic 75W-90 or 10W-30. Brand is up to you but a change of fluid sometimes makes things work better. It did in mine.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 8 Old 09-13-2013, 10:01 AM
jjh
That is exactly what is wrong with mine. I would still check all your fluids though. I have been driving mine for a little also and I am used to it already. Only grinds when I am driving like a @ss which is rarely
1994 Sahara YJ - 3.5 BDS suspension, 5/8" boomerang shackles, 33"x12.5 Hankook mud terrains, Tom Woods custom drive shafts, SYE, G2 4.56 gears front and rear, 81K original miles, plus a lot more.
jjh is offline
post #5 of 8 Old 09-13-2013, 01:41 PM
atldude
I was told that this was a common issue. Mine also does it in 2-nd and 3-rd. yea it will make you drive like a suburbian soccer mom in no time!
atldude is offline
post #6 of 8 Old 09-15-2013, 06:51 PM Thread Starter
the_hub49
That all seems like a step in the right direction. Am I missing it or is there no tranny dip stick in the engine bay? It had a full tranny fluid flush last year and Royal Purple put in. But I will be checking the levels. If it isnt the levels what does that mean for my transmission? Is it on its way out or can I just drop it and replace something simple or do I get a better one and call it good?
post #7 of 8 Old 09-15-2013, 07:07 PM
bigbossd1030
There is no dip stick. You have to pull the fill plug and stick your finger in.
In my opinion, it's your syncros. Eventually they will have to be replaced. I cannot see your info on my phone. What tranny and year??
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #8 of 8 Old 09-16-2013, 07:37 PM Thread Starter
the_hub49
Ya i though so, just as easy i should get used to crawling under this thing. Its a 90 YJ stock tranny.
