Go fast jeep yj, need advice - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Go fast jeep yj, need advice
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW!! HMF 50"-52" light bar mounting brackets!! Year End Clearance Sale! Save 20%
Unread 06-21-2014, 08:44 PM   #1
ahar9
I'm building kind of a jeep speed Yj. I want to keep leaf springs so I know it won't be outstanding but what leaf springs should I use for a jeep speed Yj. Gonna run an 8.8 and Dana 30 with 4.10 gears and 33s or 35s. Need shock advice to. Don't know much about shocks and valving and all that. Want a setup that will ride smooth and steer well through bumps and turns
if nothings breaking your not wheeling it hard enough
ahar9 is offline   Reply With Quote Quick reply to this message
Unread 06-21-2014, 09:06 PM   #2
youngjeepr
What do you mean by a go fast jeep? Are you taking it down the strip as a sleeper? Or do you want to do some type of offroad racing?
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
Utah Jeep Crew
Build Thread
youngjeepr is offline   Reply With Quote Quick reply to this message
