GM HEI upgrade? - JeepForum.com
post #1 of 6 Old 06-12-2001, 08:54 PM Thread Starter
SFM1AE2
GM HEI upgrade?
I have a 87 YJ. I'm running a MSD coil and MSD 6AL ignition box routed through the old jeep ignition box. Can anyone tell me how to wire up a HEI ditributor with my MSD box? Can I cut the old iginition box out of the loop? Thanks in advance.
87YJ I-6 Offenhauser intake Holley 4bbl MSD 6AL box
SFM1AE2 is offline
post #2 of 6 Old 06-25-2001, 02:04 PM
mike byrd
don't bother with the HEI.... go to your local auto parts store and get a cap, rotor, adapter and wires for a '97 Ford pickup with the 300cu six cylinder....you'll be amazed and you don't have to modify ANYTHING. The distributor in your jeep is a motorcraft, the same exact one that's in the ford truck, except jeep used a smaller car that really restricts the spark/rpm..
'90 YJ, 4.2 liter, 4"Pro Comp Lift, lookin for other goodies.
mike byrd is offline
post #3 of 6 Old 09-10-2001, 05:53 PM
B2hi
All you need to connect the HEI is a switchable 12v source and connect the tac wire. HEI can be expensive. $255 to $350.
Check www.performancedistributors.com
87 Wrangler 4.2
Mopar MPI
4.0 Head
Throttle body spacer
K+N air filter
Con-ferr shackles,R.E. 4.5 lift with 33x12.5 BFG Muds and 1in. body
B2hi is offline
post #4 of 6 Old 09-11-2001, 06:06 PM
renegade0351
mike,
what adapter are you talking about ?
89 sahara, 4.2 , k551 weber, nutter bypass, tuffy stereo security console & under seat security drawer, 4'pro comp & 3'body, front waggy44 w/detroit & 4.88, rear waggy44 w/detroit & 4.88, teralow sye, tw's cv drive shaft {rear}, warn locking hubs, boomerrangs all around, 35x15.50 tsl-sx swampers { love that roar}.
renegade0351 is offline
post #5 of 6 Old 09-13-2001, 08:19 PM
87yj350
When I had a 6 in my jeep I did a HEI swap it is hands down better then the ford dura spark crap. The idle was not choppy and the mileage increased. I got the dist out of an old 292 chevy motor then ordered the gear right from mopar. Had about $100 into the whole swap. I would recommend it to anybody with a carbed yj.
87yj350 is offline
post #6 of 6 Old 09-18-2001, 11:34 AM
glm 87 wrangler
cape cod conversions can help you out with the whole set up for about 220.00 dollars
They also have TFI kits. Dont know how well it works but there web site is very info..even tells how to install right on there site.Having problems with timming on mine.Just dont have the cash right now.Email
glenn105@yahoo.com He sells the thing and has all the info you need..May try the ford 300ci
trick first.
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
Best headlight upgrade for a TJ that does not require new wire upgrade? Rescue06 TJ Wrangler Technical Forum 95 06-10-2015 06:46 PM
rubicon express LA upgrade or clayton LA upgrade jeepin01tj TJ Wrangler Technical Forum 11 01-30-2010 06:05 PM
First upgrade notaleg13b JK Wrangler Technical Forum 2 04-27-2007 01:58 PM
Upgrade 2.5LT? How? Airborne4X4 TJ Wrangler Technical Forum 20 02-05-2006 08:50 PM
Better Upgrade? Brassmonkey TJ Wrangler Technical Forum 9 04-26-2004 04:39 AM
