GL-4 or GL-5? - JeepForum.com
post #1 of 23 Old 06-17-2013, 10:44 AM Thread Starter
ddtt225
GL-4 or GL-5?
Here's my question for everyone.
I've been told on numerous occasions that for our particular model transmission (ax-5) that we are supposed to use only GL-4 80w-90 gear oil. Something with the sulfur in the GL-5 eats away at the brass syncros and causes harsh shifting. YET in all of our owners manuals it states to use GL-5? Can anyone help me with this? It's been bothering me for a few days and I would love some clarification. Thanks.
ddtt225 is offline
post #2 of 23 Old 06-17-2013, 10:47 AM
Agent620
I thought it was GL-5 that ate the stuff. that was the case with my CJ5's transmission anyways. Had to use GL-4 for that reason. I am somewhat confused by your post. You seem to switch it around.
Thanks to Anticanman who gave me a membership!
Chris Hansen is reading this thread.
If you've ever been in that traffic, you would have ground down the steering wheel with a death grip too. "Just ****ing GOOOOOO!!!!"
I pitty anyone who tries to reach into that netting unaware.
'99 TJ (DD)
'89 XJ (WIP)
Agent620 is offline
post #3 of 23 Old 06-17-2013, 11:19 AM Thread Starter
ddtt225
I meant it as I was told to use GL-4 instead of GL-5. But in the manual it states to use GL-5. I was trying to figure out why not to use the recommened oil and go with the GL-4 instead.
ddtt225 is offline
post #4 of 23 Old 06-17-2013, 11:33 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
There was a recommendation change to use 10-w40 for the ax-15 and I believe the 5 as well.
Anticanman is offline
post #5 of 23 Old 06-17-2013, 11:37 AM
Rproject
1987 YJ Wrangler
That was the recommendation I received back when I had an AX-5. I switched to 10-w40. Not sure if that was the reason, the simple fact that the PO never performed regularly scheduled maintenance, the way my son drove it, or that it had 175k miles on it, but a year later we lost 2nd and reverse at the same time. Ended up replacing it with a $200 bone yard AX-5 then sold it three weeks later. What a turd that AX-5 was. Between 5th gear going away and the overall light duty nature of the trans, I'm SO happy I dropped it like a bad habit.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #6 of 23 Old 06-17-2013, 11:46 AM Thread Starter
ddtt225
Well right now in the transmission I have GL-4...but the weight is ungodly. GL-4 140..don't think I'm pushing a tractor transmission or steering gear box.
ddtt225 is offline
post #7 of 23 Old 06-17-2013, 11:48 AM
jsipe007
I have always read/been told to use GL-4 in the manual transmission. I have also heard about the switch to 10w40 but currently am using redline synthetic 75W90 GL-4 oil in my wrangler.
I did a bit of research and the general consensus was to use GL-4 since it is not as hard on the synchros. Im quite surprised your manual said GL-5... mine said GL-3. GL-4 i believe is considered to be a substitute for GL-3.
EDIT- I was thinking of my Haynes manual GL-3 spec. You are absolutely right, Chrystler listed GL-5 in the manual. Maybe this was for jeeps with only auto trans?
Here is an interesting read: http://www.bobistheoilguy.com/forums...&Number=498190
jsipe007 is offline
post #8 of 23 Old 06-17-2013, 11:56 AM
dancytron
I remember reading a post on here that Chrysler made a mistake and put GL-5 in some of its manuals, but that then they changed it.
I think what Chrysler recommends is 10w30, not 10w40 (although it probably doesn't make a difference).
You could call the dealer and see what they say if you are really concerned.
dancytron is offline
post #9 of 23 Old 06-17-2013, 12:06 PM Thread Starter
ddtt225
10w30? This will sound stupid, but are they talking about gear oil weight or motor oil weight? If that's the case I have a bunch of 10w40 oil sitting in my tool box.
ddtt225 is offline
post #10 of 23 Old 06-17-2013, 12:09 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sorry. I meant to type 30. Stupid iPhone. And yes, motor oil not gear oil
post #11 of 23 Old 06-17-2013, 01:07 PM Thread Starter
ddtt225
Well I called my dealership about it and yes it is 10w-30 motor oil that is in the transmission.
ddtt225 is offline
post #12 of 23 Old 06-17-2013, 01:16 PM
Destr0
Been running 10w-30 synthetic (whatever is on sale!) in my AX-5 since I got it 4 years ago. Had almost no sychros left when I got it, and it is still going, even after much abuse. I have an AX-15 sitting in my garage but every time I run into the elusive Dakota bell housing I have no extra cash.
1994 Jeep YJ off road toy
1981 CJ7 SBC 350
2005 KJ Libertyt 4x4 CRD w/ 2.5" Frankenlift DD
Destr0 is offline
post #13 of 23 Old 06-17-2013, 01:43 PM Thread Starter
ddtt225
I didn't think the ax-15 would bolt up to the 4l?
ddtt225 is offline
post #14 of 23 Old 06-17-2013, 03:21 PM
gunshw301
It won't. You need a 4 cylinder Dakota bell housing or aftermarket adaptor to mate them. It's on my list.
I have also been using 10w30 for about two years now, all is well.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #15 of 23 Old 06-17-2013, 04:15 PM Thread Starter
ddtt225
I appreciate all the help guys, I work in a dealership so I have access to lifts, my tools, all the goodies lol so draining and changing out wont be a problem. Anyone have any recommendations on conditioning the tranny before new fluids go in it? Just want to make sure EVERYTHING is top notch on the inside so I don't have any problems out if it.
ddtt225 is offline
gear oil , transmission , weight
