Getting a high reading on fuel pressure test - JeepForum.com
post #1 of 10 Old 03-04-2014, 11:49 PM Thread Starter
JackTupp
I've been having some trouble starting the 95 4.0L. It starts and runs well but I have to pump the gas or hold the pedal down then it just barely starts. So I ran a fuel pressure test on the MPI fuel injection. I received a psi of 48 and no change when I detached the line from the vacuum assisted pressure regulator. The book says to check the return fuel line. I can't determine which is the return line. Is the pressure regular bad?
JackTupp is offline
post #2 of 10 Old 03-05-2014, 06:35 AM
Jeepsr4me
return lines are always smaller..
Jeepsr4me is online now
post #3 of 10 Old 03-05-2014, 08:29 AM
Que89YJ
The return line comes off the pressure regulator. Disconnect the return line from the regulator. Take a piece of hose and put it on the fuel rail and run it to a gas can. Start and check your pressure again. Then shut it off. If the pressure drops then the issue is the return line and you need to repeat the process by disconnecting it at the tank. If it stays high then the regulator is bad.
Que89YJ is offline
post #4 of 10 Old 03-05-2014, 09:23 AM
jsipe007
Que will be able to help you, I had a very similar issue not long ago.
Sounds like fuel pressure isnt staying at the fuel rail in addition to the high fuel pressure. Did you check the pressure after shutting the engine off? pressure should hold at the fuel rail. I dont know the exact specs but they're available online. If it doesn't hold fuel pressure, the fuel pressure regulator is likely bad. Be careful though and don't assume it is only the regulator. High fuel pressure is generally caused by a blocked return line. If you install a good fuel regulator, the high fuel pressure can cause it to fail again.
is your tub in good shape? I only ask because there is a spot in the rear of the jeep where the fuel lines go between the tub and frame. It is a common area to find a pinched return line (unless you have a body lift)
jsipe007 is offline
post #5 of 10 Old 03-05-2014, 09:45 AM Thread Starter
JackTupp
Thanks for the info. I'll go after the return line. My tub is in good shape and I have a body lift.
JackTupp is offline
post #6 of 10 Old 03-05-2014, 05:16 PM
Mark05059
there has also been times when the hoses get pinched when the tank is dropped and reinstalled.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #7 of 10 Old 03-05-2014, 05:38 PM
Que89YJ
The pinched line is why you do it again at the tank if it stays high. If it is normal at the tank fuel line then its the return line in the tank.
Que89YJ is offline
post #8 of 10 Old 03-09-2014, 12:10 AM Thread Starter
JackTupp
Just went through the return line. Chased it all the way to the tank. The return line in the tank had sunk down and was pushed against the bottom of the tank. I cut the return tube down a quarter inch and the supporting washer. runs like a champ.
JackTupp is offline
post #9 of 10 Old 03-09-2014, 12:36 AM
jsipe007
Sweet! Same exact solution as in my yj.
jsipe007 is offline
post #10 of 10 Old 03-09-2014, 07:56 AM
Que89YJ
It seems to be happening a lot. Glad it is running better.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
