Getting A Battery That Fits 89 yj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Getting A Battery That Fits 89 yj
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Billet LED Tail LightsCurrie
Unread 11-26-2014, 04:14 PM   #1
YJRob89
I needed a new battery for my 89 yj. Everyone said I needed a group 58. Problem is none of the 58 batteries fit in the tray. Turns out the battery I had in there was a group 56 c-10 sears diehard which fit the tray with no problems. Ended up getting a group 26 which barely fit the tray after cutting off the hold down lip on the bottom of the tray.
What standard battery is everyone using? Did you have to modify your battery tray to accommodate the newer batteries?
I found the sticky on installing dual batteries and I plan on installing dual batteries in the future because I use the jeep mainly for plowing and after awhile the lights do start to dim. But my old battery lasted 8 years, used only for plowing and sat in the yard until the following season.
YJRob89 is offline   Reply With Quote Quick reply to this message
Unread 11-26-2014, 09:16 PM   #2
87TPIYJ
1987 YJ Wrangler
I think 89s still had the posts of the batter front to back. Can you weld. If so go pick up some angle iron and flat stock. Really simple to fit a group 65.
http://www.matanzasjeepclub.org/foru...p=57562#p57562
87 YJ, 350 TPI, 35x12.50x17, SOA, HPD30 locked, 8.8LSD, TT
87TPIYJ is offline   Reply With Quote Quick reply to this message
Unread 11-26-2014, 09:49 PM   #3
mike134
If you're going to build a tray, build one big enough for two batteries in case you want to upgrade in the future!
mike134 is offline   Reply With Quote Quick reply to this message
Unread 11-28-2014, 05:30 PM   #4
Tshark299
1987 YJ Wrangler
Earlier YJs had a Group 56, later was Group 58. I believe '91 was when they switched to the 58 but don't quote me exactly on the year.
'87 YJ Laredo - 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
'95 XJ - Donated drive train to the YJ, Parted out the rest
'51 CJ-3A - Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline   Reply With Quote Quick reply to this message
Unread 11-29-2014, 11:15 AM   #5
YJRob89
That would explain the narrow tray.
