General OME leaf spring question - Page 2 - JeepForum.com
post #16 of 19 Old 02-06-2013, 10:07 AM
Chrisnvegas
Chrisnvegas's Avatar
Originally Posted by CBinDC View Post
Thanks for the tip! I think that's what I'm gonna do. Does the rear look parallel to the front - did you measure it? Yeah, wheel travel and going fast over bad terrain sounds great to me!
The rear is about 1/2 inch higher than the front. Can't really tell unless I measure it though.
If your Jeep is similair to mine, 4.0 automatic, soft top, no winch, 20 gal fuel tank, light spare it should ride great if you do what I did. My Jeep replaced my well built Rhino after watching several Rhino accidents. I just didn't trust them anymore. Also, the Rhino started using oil after 3500 miles and I took good care of it. 3500 miles? That's one Jeep oil change!
This Jeep will whoop my Rhino's butt and I had $15,000 into the Rhino.
Let us know what you decide on.
My Jeep is NOT a Fiat!
Chrisnvegas is offline
post #17 of 19 Old 11-06-2014, 07:11 AM
YnotJ92
Hey Crisnvegas
If youve still got 14f for the front, then you and I have different setups.... Ive got 37r in the front. Thats the "light duty" rear spring....
YnotJ92 is offline
post #18 of 19 Old 11-07-2014, 08:51 AM
Lemoore-on
I have 36R's front & back. I have the 2.5L, warn 9000 in front & 1/2" boom shackles, an 8.8 in the rear with 1" lift booms. A swing out tire carrier 33" spare & Jerry can. No sway bar or track bars.
My front sits a full inch higher than the rear. The rear sags even more with camping gear. It rides great even with crappy shocks. I'm going to replace the rear springs with 3.5" BDS springs soon and Bilstien shocks, add some extended bump stops and probably go back to stock length shackles in front.
I use my Jeep for rock crawling, trail rides, Hunting rig & I drive it regularly (because its fun)
Mike
92YJ with some stuff done to it.
Lemoore-on is offline
post #19 of 19 Old 11-08-2014, 12:23 AM
YnotJ92
Snapped a pic at the mechanic today
10460618_10205525205757801_147029813723447268_o.jpg   1522444_10205525209077884_677312685778121030_o.jpg
YnotJ92 is offline
