Which Gears??? - JeepForum.com
post #1 of 3 Old 01-21-2010, 01:02 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Which Gears???
1st question. Which gears? unable to read it off the pumpkins due to years of coorosion and paint.....Any other means? I'm assuming (if factory) the gearing is same front and rear..yes?
Dana 30 Front and the 35 rear...
Running 33 AT's on a 4.0 is there a recommendation on what is best? 3:73, 4:10, etc?
I might go some mild off roading/ trails but by no means will I be hard core....
If I change the rear do I have to match the front?
Thanks
NHfireLJ is online now
post #2 of 3 Old 01-21-2010, 01:08 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
http://www.jeepforum.com/forum/f12/y...-specs-563403/, and yes they are the same
either or would be fine for on road IMO
yes
Thanks
You're welcome
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 3 Old 01-21-2010, 01:13 PM Thread Starter
NHfireLJ
NHfireLJ's Avatar
Thanks Martin......
Yukon 4.88 gears on back order, what gears would be just as good? N2SPD TJ Wrangler Technical Forum 20 02-06-2011 08:19 PM
Jk Rubicon 4:10 gears vs. 1974 Chevy 4:10 gears (pics) Xtremjeepn JK Wrangler Technical Forum 15 12-03-2009 09:09 PM
Removing side gears and spider gears... Mudbug1979 TJ Wrangler Technical Forum 2 10-08-2009 06:34 AM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 09:55 AM
Will a differnece be noticed from 3.07 gears and 33" tires to 3.73 gears chaznad TJ Wrangler Technical Forum 9 08-26-2005 10:54 AM
