gears? - JeepForum.com
post #1 of 5 Old 09-20-2001, 08:54 PM Thread Starter
Bassili
gears?
So I'm getting a 4inch suspension lift (procomp i think) and 33x12.50R15s to go on 15x8 rims. Am i going to have any gearing problems and will all gears still be usable?
Thanks alot
88 YJ Laredo 3 inches suspension, 33x12.50s, 4x Warn driving lights
Bassili is offline
post #2 of 5 Old 09-20-2001, 08:58 PM
RodeoRob
RodeoRob's Avatar
Here's a link for ya: http://www.4wheelparts.com/Tirel_gear_ratio.asp
do you have an auto or manual? you'll take a noticable hit, but it will still be drivable. you'll probably want a gear upgrade sometime in the near future.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 5 Old 09-20-2001, 09:05 PM Thread Starter
Bassili
It's a standard. What's the stock gear ratio cause I'd bet that's what I have and what do u mean by take a hit?
Bassili is offline
post #4 of 5 Old 09-20-2001, 09:41 PM
RodeoRob
RodeoRob's Avatar
i mean your acceleration would suffer (take a hit). You have a 6cyl? More than likely, your ratio is 3.07 stock. you can look on the rear diff cover and there should be a small metal tag on two of the bolts indicating your gearing ratio. You'll pretty much loose the use of 5th gear by running 33's and it will take you a little while to climb to 60-65 on the highway.
I'd recommend going to 4.10s... or 4.56 if you want more offroad performance.
-Rob
Robert Gorrell
RodeoRob is offline
post #5 of 5 Old 09-20-2001, 11:07 PM
osburn
osburn's Avatar
I think to sum up what he's been say'n, "It's doable, but you ain't gonna like it."
Matt Osburn
Score 1032
osburn is offline
Yukon 4.88 gears on back order, what gears would be just as good? N2SPD TJ Wrangler Technical Forum 20 02-06-2011 08:19 PM
Jk Rubicon 4:10 gears vs. 1974 Chevy 4:10 gears (pics) Xtremjeepn JK Wrangler Technical Forum 15 12-03-2009 09:09 PM
Removing side gears and spider gears... Mudbug1979 TJ Wrangler Technical Forum 2 10-08-2009 06:34 AM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 09:55 AM
Will a differnece be noticed from 3.07 gears and 33" tires to 3.73 gears chaznad TJ Wrangler Technical Forum 9 08-26-2005 10:54 AM
