Gearing Questions. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Gearing Questions.
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 07-09-2012, 01:08 AM   #1
DontTouchIt
Gearing Questions.
I am currently running 4.10s with 35s. I have a 4.0 with a good intake, header and a free flowing exhaust. Also have a 5 speed trans. I have been looking around at other forums and seeing that most people are saying that 4.88 is a good ratio for 35s, even using it on the freeway. with my current setup I am able to tach about 1500 at 70 and get around 16-19 mpg. Will running 4.56 hurt me much or just give me more responsive throttle?? I am also planning on adding a bit of cage and fullsize spare W/ swing out carrier. Thanks
DontTouchIt is offline   Reply With Quote
Unread 07-09-2012, 06:25 AM   #2
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
4.56 should be good for you. I ran 35's with 4.10's. It was OK but 4.56 would have been better.
Poke is offline   Reply With Quote
Unread 07-09-2012, 07:37 AM   #3
mrmark
mrmark's Avatar
4.56's is an expensive change for the difference you are going to get.
I have a 2.5 and 4.88's on 35's and it's a struggle to hit 60, but the 4.0 is a much stronger engine. I just can't see spending the money and not going all the way is all. How fast do you want your top end to be?
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline   Reply With Quote
Unread 07-09-2012, 08:44 AM   #4
DontTouchIt
Well the only reason that I am asking about regearing is because I have a hp dana 44 I am going to narrow and it needs to be regeared and locked. I figured it would only run me about $500 to have some new gears put in the rear. I do like having the 80 something mph topend I have now. I do kinda have to nail it in fourth up most hills on the interstate.
Unread 07-09-2012, 09:55 AM   #5
Anticanman
Luck Favors the Prepared
Anticanman's Avatar
If its your daily driver I would keep the 4.10 and possibly get lower gearing in your transfer case if you do any rock crawling.
Anticanman is offline   Reply With Quote
Unread 07-09-2012, 06:24 PM   #6
DontTouchIt
It is a dd, and we don't have jack for rocks in most of Oregon. Does anyone know the rpm in 5th gear running 35s with 4.56 gears??
Unread 07-09-2012, 07:04 PM   #7
mrmark
mrmark's Avatar
Let's talk gear changes in the transfer case please. I am new to this concept and was suggested this 2 weeks ago by someone else.
I am already starting in 3rd on level ground with the gearing I have in 4Low. Would there be any benefit from me changing the gearing? I would think I am already geared high enough ...
Opinion?
Unread 07-09-2012, 07:53 PM   #8
G30SFF250
I can't imagine running 70 MPH in my YJ.
Anticanman, I have told people about what you did.
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline   Reply With Quote
Unread 07-09-2012, 09:36 PM   #9
DontTouchIt
When I was trying to see the total top end of my jeep, I had it up to 93 going down a grade. Bit sketchy but still worth knowing what it could do. I have heard that doing anything to the NP231 is a waste of money, unless it's a SYE. A NP241 already has a 4:1 low in it.
Unread 07-10-2012, 12:53 AM   #10
Anticanman
Anticanman's Avatar
Opinion?
Sounds alright. Try it on the rocks and it'll really tell you.
I don't know what you're talking about.
Good luck finding one.
Unread 07-10-2012, 06:34 AM   #11
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
you heard wrong. The NP231 is not the end all be all of production t-cases, the NP205 is. But the 231 is a good solid case. They are stupid simple to work on, light weight, and require little to no maintenance.
I run one on the hardest trails pushing 40's. jumped, beat, tires spinning bouncing... I broke one once because of driveshaft clearance, it was my fault for not giving it enough room.
I'd say for 35's and less it is perfect. If I was sticking with a jeep power plan and t-case i would keep the 231 and order everything JB has to offer to build it up, wide chain, hardened shafts, etc..
Unread 07-10-2012, 08:10 AM   #12
tankinyj
2015 YJ, the hell?
[QUOTE=SFRautomotive;11992287]will a 3" body lift on my XJ still keep me LCG???[/QUOTE]
2012 JK 2Dr Crush Orange, 4.56's, 3" on OME springs and shocks, 35x12.50x15 MT/R's
RIP: 1994 YJ, 4.0L, AX15, NP231, 8.8, 31" AT tires, 2.5" lift
tankinyj is offline   Reply With Quote
Unread 07-10-2012, 08:28 AM   #13
mrmark
mrmark's Avatar
What is a rock? I live in Florida
Unread 07-10-2012, 09:14 AM   #14
Siva283
ID 10 T error
Siva283's Avatar
Originally Posted by tankinyj View Post
2015 YJ, the hell?
I have been wondering that myself. I figured it was a response to Jsawduste's 2006 one. He built it from parts so it got assignned a 2006 VIN. Seems many people do not beleive him though. However if you talk to him it is obvious he could do it in his sleep.
1995 YJ. 2 inch BDS Spring lift. 1 inch shackle lift. 33x12.5x15's. Engo 10,000 pound winch.
Big difference between a Warn winch and a worn wench. I'll take the former.
Originally Posted by Que89YJ View Post
Oh and the phrase high cfm doesnt do that fan justice. It could suck peanut butter through a straw!
Siva283 is offline   Reply With Quote
Unread 07-10-2012, 12:39 PM   #15
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
2015 YJ, the hell?
yes.
no.
35s , gearing , power
