Gear swap - JeepForum.com
post #1 of 6 Old 01-01-2012, 11:07 AM Thread Starter
Supertrey
Gear swap
I found this in the stickies:
Rear Axles
Dana 35 non c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used '87-'89
Dana 35 c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used '90-'95
I found a great deal on a carrier and ring and pinion from a 1989 YJ with 4.10 gears.
If I read the above info correctly, this will not work in my 1992 YJ because of the C-Clip axles in my '92?
Supertrey is offline
post #2 of 6 Old 01-01-2012, 11:58 AM
94chb
the carrier and ring n pinion doesnt have anything to do with the C clip or Non C clip
94chb is offline
post #3 of 6 Old 01-01-2012, 12:07 PM
NHfireLJ
NHfireLJ's Avatar
fill in your profile...
Regearing is expensive.. cheaper to find axles with the gearing you want and swap them in..
What are your plans, regearing / swapping a D35 is a waste , Research ford 8.8..
http://www.jeepsunlimited.com/forums...d.php?t=371713
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #4 of 6 Old 01-01-2012, 12:45 PM
roadyrob
1987 YJ Wrangler
they will work, but do you have the knowledge to do the swap yourself? if yes then nothing wrong with spending a few extra bucks to end up with a rebuilt rear end. if no and you will be paying someone to do it just find another rear with the gears you want.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #5 of 6 Old 01-01-2012, 01:18 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
What you need to know/find out, is if the replacement non c-clip carrier will accept the c-clip style carrier side & possibly spider gears too.
Reason being - the c-clip style side gears are machined differently so that they accept the c-clips while the non c-clip side gears will not. IIRC, there could be size differences between the two types.
It *might* be a simple case of using the old side gears (and *maybe* the spider gears too) if the carrier allows.
One other factor you may need to consider is if the non c-clip carrier still has the carrier bearings pressed on it. If it does & you don't get the races with it - then you will be doing a mix-match of the bearing parts.
Plus, you *may* need to remove the old carrier bearings and press them on the other carrier. If not successful - new bearings will be needed. If the bearings are old or worn - you'll want new ones.
You're gunna need shims, gear marking compound, probably a new pinion gear crush sleeve, seal etc since the gears will need to be set-up not to mention the tools required.
Joe Dillard is offline
post #6 of 6 Old 01-01-2012, 02:08 PM Thread Starter
Supertrey
I am going to do the swap myself, with the help of a friend who has the right tools and has done several. That should negate the labor charge. I have found several sources locally for the gears and carrier, coming in under $100 bucks.
I have researched the waggy d44s and the 8.8s and have decided to go D44 long term.
In light what you pointed out about the machining, I will stick with the carrier out of the 90' and up non abs so I stay on the safe side.
89 dash swap and gear shift swap? (Help) SeanC1355 YJ Wrangler Technical Forum 0 07-29-2011 10:12 PM
1st gear swap? rtyler13 TJ Wrangler Technical Forum 4 12-29-2009 09:29 AM
Gear Swap or Axle Swap? Zazoos YJ Wrangler Technical Forum 3 06-02-2009 11:29 PM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 09:52 AM
