Gear shift hard to move in neutral when hot - Page 2 - JeepForum.com
post #16 of 16 Old 02-02-2013, 11:02 PM
ROTTEN
Originally Posted by Northinger View Post
Not to steal the thread but i have a similar issue but when its cold, is this normal?
Ha! Yeah mine barely moves until I get going and the fluid starts to warm.
I got a trick that seems to help me with that issue. While I sit and let the engine warm up I hold the clutch and just shift the shifter through the gears. Seems to churned it up enough so I can shift a tad bit easier.
-15 it barely wanted to move.
I also read if you put your t case in neutral and leave your trans in first it will spin the gears and warm it up. I have not tried this yet.
I'm concerned about draining my stinky gear lube out of my trans and running oil or synchromesh. I fear that it won't like the new fluid. Maybe I'm just paranoid?
I'm new
ROTTEN is offline
YJ Hard to shift into 1st gear Dwatts5250 YJ Wrangler Technical Forum 35 07-11-2013 05:37 PM
AX15 grinding or chattering in neutral hard shift xwildman138x YJ Wrangler Technical Forum 102 06-02-2010 07:29 PM
1990 YJ Auto, hard to shift into neutral or park from drive Nokinja YJ Wrangler Technical Forum 1 08-15-2009 08:30 PM
88 YJ Won't shift when started from neutral, works fine when started in gear NateWithoutBeer YJ Wrangler Technical Forum 2 06-20-2009 04:40 PM
Wont shift into gear from neutral? Duncan71 YJ Wrangler Technical Forum 0 01-19-2009 06:56 PM
