Gear shift hard to move in neutral when hot - JeepForum.com
post #1 of 16 Old 08-31-2008, 06:44 PM Thread Starter
spshultz
1987 YJ Wrangler
Got an odd problem with the trans when it gets hot.
When the Jeep is cold the trans is very easy to shift. Very smooth. The shifter will move side to side easily and it will spring back to the center position. I don't have any issues with it when it's cold or just a little warm.
But, when the Jeep gets hot the trans gets real hard to shift but that's because the shifter will not spring back to center when you come out of a gear. And, in neutral it's really hard to move side to side. It feels like the plastic concave thing the shifter ball sits in it swelling up and gripping the shift ball. It feels "sticky". Once it cools down (usually about an hour) it's nice and easy to move and shift again.
When I put the shifter back in (replaced a borked BA10/5 with a good/working BA10/5) I did not grease the ball. Was I supposed to? And if not, what in the world is causing this?
Thanks!
Shawn
spshultz is offline
post #2 of 16 Old 08-31-2008, 08:14 PM
bigredcherokee
2011 WK
Make sure that you have gear oil in it. Do you have any leaks? when was the last time you changed the gear oil?
For those of you in Louisiana visit
bigredcherokee is offline
post #3 of 16 Old 08-31-2008, 08:24 PM Thread Starter
spshultz
1987 YJ Wrangler
Some humility time here.... :-(
Unfortunately I don't have a pipe plug socket to take out the plug to check the oil.
But before I put the trans in, I looked down inside the hole and could see oil. Just couldn't see how high it was but it "seemed" high.
I added a little GL-5 (didn't know at the time that GL-5 isn't the best for these transmissions) and then put the trans into the jeep.
There are no leaks so that's either a good thing or a bad thing.
No clue on when the guy I bought the trans from changed the gear oil.
Hmmm.....well, I guess then it's time to check the oil.
I tried making a pipe plug socket out of a 3/8" extension but it ended up just twisting in half because the plug is in there so tight. And the extension I used wasn't of the highest quality either. Where do you get a proper socket for this type of plug?
I have two full bottles of Syncromesh sitting in the garage that I had purchased for another car's trans that I never got around to doing. If this trans uses yellow synchro's then using the Syncromesh should be fine?
And thanks for the reply. :-D
spshultz is offline
post #4 of 16 Old 08-31-2008, 09:06 PM
pat8942
pat8942's Avatar
This ain't gospel,but I think the plug is 7/16 square.
Since nowhere except France maybe is there such a thing as 7/16 drive,You'll have to get creative and make yourself a tool.
Somebody on the forum will probably chime in soon that is more knowledgeable than I on the BA10/5
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #5 of 16 Old 09-01-2008, 07:56 AM Thread Starter
spshultz
1987 YJ Wrangler
I found a "Drain plug" set on Harborfreight. 12 sockets total - 2 standard sizes and 10 metric. Hopefully that will be what I need.
spshultz is offline
post #6 of 16 Old 09-01-2008, 08:35 AM
pasinbuy
You might have water in there.
pasinbuy is offline
post #7 of 16 Old 05-15-2012, 04:57 PM
Ant954
I found this old post. I also have an 87 YJ and have this exact same problem. Does anyone else have an idea on what causes this. The problem has been there before and after I had my tranny fluids flushed.
After about a half hour of driving my shifter stick will "gum up" on me. its most noticable when im moving the stick left and right in neutral. It doesnt have the smooth slide like when i first start driving it. This thread is the only place ive found the same problem as mine and just wondering if anyone knows any info on it.
Thanks
Ant954 is offline
post #8 of 16 Old 05-16-2012, 11:02 AM
Ant954
anyone? Any input is appreciated.
Thanks
Ant954 is offline
post #9 of 16 Old 09-22-2012, 05:55 PM
camaro74
87 jeep shifts hard when hot
My 87 jeep shifts hard when it gets hot. any coment on the problem will be appreciated.
camaro74 is offline
post #10 of 16 Old 02-02-2013, 03:45 PM
James0505
Did anybody ever figure this out, I'm having the same problem. I got water in mine, so i changed the fluid but still hard to shift when hot.
James0505 is offline
post #11 of 16 Old 02-02-2013, 03:53 PM
Mark05059
what kinda fluid did you put in it?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #12 of 16 Old 02-02-2013, 04:00 PM
James0505
75w-90 full synthetic gl5,that's what the book said to use. It definitely had gear oil in it before I changed it.
post #13 of 16 Old 02-02-2013, 04:14 PM
Mark05059
yeah that was what the original book said.. they found that the fluid was too heavy for it.. it calls for 10w30 motor oil.. get the cheapest stuff you can find at walmart and run it for like a few hundred miles and then change it again.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #14 of 16 Old 02-02-2013, 04:25 PM
James0505
I will give that a try. Any idea why it shifted fine before with gear oil in it?
Thx for the help
post #15 of 16 Old 02-02-2013, 04:39 PM
Northinger
Not to steal the thread but i have a similar issue but when its cold, is this normal?
Northinger is offline
YJ Hard to shift into 1st gear Dwatts5250 YJ Wrangler Technical Forum 35 07-11-2013 05:37 PM
AX15 grinding or chattering in neutral hard shift xwildman138x YJ Wrangler Technical Forum 102 06-02-2010 07:29 PM
1990 YJ Auto, hard to shift into neutral or park from drive Nokinja YJ Wrangler Technical Forum 1 08-15-2009 08:30 PM
88 YJ Won't shift when started from neutral, works fine when started in gear NateWithoutBeer YJ Wrangler Technical Forum 2 06-20-2009 04:40 PM
Wont shift into gear from neutral? Duncan71 YJ Wrangler Technical Forum 0 01-19-2009 06:56 PM
