Gear Ratio with V8 - JeepForum.com
post #1 of 6 Old 05-20-2010, 11:11 PM Thread Starter
cubewhiz
Gear Ratio with V8
I will probably swap a V8 under the hood next summer (this summer I have too much to do on the other vehicle). I use my Jeep as a DD. Would 4.10 gears be low enough for a good ride or would I want to regear also? My poor 4 banger won't let me climb some hills on the highway faster than 50 mph (or sometimes less!).
Thanks.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #2 of 6 Old 05-21-2010, 04:34 AM
Devilnutzusmc
if you have a 4 banger then you are already geared 4:10 from the factory. you could regear to 4:56 but this is costly to do to both axles. The most cost effective upgrade would be going to 4.0 litre straight 6. or just do what I am doing with my 4 banger.....scrap it and drop a 5.2 hemi in!
Devilnutzusmc is offline
post #3 of 6 Old 05-21-2010, 05:55 AM
clush
Given that your concern is getting up hills on the freeway - While I don't have any experience w a V8 YJ, I would think the extra torque and hp would more than be enough w 4:10's/33's, especially if you use a torqey cam/intake/head setup. I know some guys that are running 410's w a 4.0L and 33's and they seem to do fine. I wouldn't go for a high reving - high hp type set up that might be used in a camaro or whatever. Look for your torque and hp in lower RPM ranges for wheelin.
clush is offline
post #4 of 6 Old 05-21-2010, 07:03 AM
MLJeeper
MLJeeper's Avatar
We throw out gear number suggestions here alot but they are all based on the factory components and years of people doing it. With a custom engine/trans you will have to run some numbers.
What transmission are you going to run behind the engine?, the gear ratio you choose should be based on calculations including your final drive gear ratio in whatever transmission you go with and the tire diameter you are going to run. Without that any number thrown out there is a pure guess. My guess is your 4.10s are going to be too low for just a 33" tire with any reasonably strong v8. IE it will suck gas as a daily driver.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #5 of 6 Old 05-21-2010, 07:12 AM
stu1021
If you are considering an engine and tranny swap, go to the Novak site and spend some time in the knowledge base. When you know what motor you want to go with research it's power band - most V8's like to run at much lower RPM than your 4 banger. Then, figure out the final drive ratio of your engine, tranny, tcase combo and what size tires you will likely run, use the calculator - Novak Conversions - Gearing & Gearing Math for Jeeps to decide what gears put you in the correct RPM range for the speeds that you will drive. This is not something to guess at. I had geared to 4.56 before my engine swap, so it was essential for me to use a tranny with a good overdrive so that my motor wasn't screaming at highway speeds.
'90 YJ Wrangler - 4.3L Chevy
'91 GMC 3500 Bus - Tow Vehicle
'87 MBenz 300D Turbo
'02 MBenz E55 AMG
'55 Piper Apache
stu1021 is offline
post #6 of 6 Old 05-21-2010, 07:29 AM
cottonmouth
Running a 350 sbc/700r4/231c combo on 44/9" axles w 4.10's and 38.5 x 11 boggers. I have PLENTY of power on the road. Like to be a lil lower for offroad, but you'll be fine....
You don't quit playing cause you grow old, you grow old cause you stop playing. PLAY HARD!
cottonmouth is offline
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
how to tell gear ratio by the ring gear YJscott2 YJ Wrangler Technical Forum 6 01-10-2010 07:30 PM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 09:52 AM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 09:52 AM
