Gear ratio help please! - JeepForum.com
post #1 of 4 Old 09-14-2011, 03:17 PM Thread Starter
frenziedYJ
im new to the jeep community (and automotive) im not sure what gear ratio i have now but im finding out tomorrow. i have a 4" suspension lift, 3" body, and raised shackles. all thats sitting on 35" all terrains. i use this as my DD its an inline 6, with a webber 36/36 DGEC carb, 5 speed manual. any suggestions on regearing? and what about lockers while im at it? would i need them? do they help that much?
Thanks, Devan
frenziedYJ is offline
post #2 of 4 Old 09-14-2011, 03:24 PM
projectsahara11
a nice gear for that size tire would be 4:88. It will help push those tires down and the road and will help off the road as well. Lockers are a very important thing to have. I would recommend the arb air lockers because with some of the other types of lockers you can't choose when and where you need the extra help from the locker. Being able to disengage your locker will not only save you money but it will help you make sharper turns on the trail.
projectsahara11 is offline
post #3 of 4 Old 09-14-2011, 04:00 PM Thread Starter
frenziedYJ
do you know were to purchase a gear set like that for a good price?
post #4 of 4 Old 09-14-2011, 04:12 PM
mmbtv
I'm using 4.88's with the same tire size and I would not gear any higher.
I believe 4.88 is as low you can go with a d30.
If you are using the stock axels, I would use an Aussie type locker.
mmbtv is offline
4.56 , gear ratio , help needed , jeep yj , locker install
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
how to tell gear ratio by the ring gear YJscott2 YJ Wrangler Technical Forum 6 01-10-2010 07:30 PM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 09:52 AM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 09:52 AM
