Gear Ratio - JeepForum.com
post #1 of 5 Old 11-15-2001, 12:48 PM Thread Starter
Dan Morera
Dan Morera's Avatar
Gear Ratio
What the gear ratio for an 88 Sahara, with the stock gear box (Peugeot piece of s...).
And is it ok to put 31/10.5r15 with everything stock, except for a cheap a.. lift.
YJ Sahara 88, 258 I6, BA/10
2.5" Susp. Lift (Aprox.), 1" Shackles 31x10.5" Cooper
Dan Morera is offline
post #2 of 5 Old 11-15-2001, 02:17 PM
YJOHN
thats well with in the limits just a note if you ever have to replace your trans with a ax15 well fit i think you have the 4.2 but get the t case with it because the spline count is differnt
YJOHN is offline
post #3 of 5 Old 11-16-2001, 02:21 PM
Cody_91YJ
Since you've got the 4.2, your ratio should be 3.07s in the diffs
'91 YJ Mangler w/ too many mods...and yet not enough ;)
Cody_91YJ is offline
post #4 of 5 Old 11-16-2001, 02:55 PM Thread Starter
Dan Morera
Dan Morera's Avatar
Cody is it safe to put 31/10.5r15 with that diff ratio?
post #5 of 5 Old 11-16-2001, 03:00 PM
Cody_91YJ
Well yes its safe, your going to lose a little power, but not much since your only going up a little in tire size. You might think about how they are going to fit though. I'm assuming you don't have any lift?? If so they should fit, but they are going to rub, you might want to look into a small lift.
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
how to tell gear ratio by the ring gear YJscott2 YJ Wrangler Technical Forum 6 01-10-2010 07:30 PM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 09:52 AM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 09:52 AM
