Gear Ratio - JeepForum.com
post #1 of 10 Old 02-27-2002, 12:56 AM Thread Starter
holkster
Gear Ratio
I am about to have a 3" BDS lift installed and 33" 12.5 tires. Dose anyone run 33" tires? If so what gears do I need? Can I run the stock 3.07:1 for awhile without trashing my Jeep?
1999 TJ 4.0l I6 Stock for now!! 4.10 gears on the way 3" BDS in the garage with hopes of 33"x12.5 BFGs
holkster is offline
post #2 of 10 Old 02-27-2002, 01:00 AM
igofshn
Locked @ both ends
igofshn's Avatar
33's with 3.07, you are going to hate life.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #3 of 10 Old 02-27-2002, 01:05 AM Thread Starter
holkster
What size tier is recomended for the 3.07 stock? I have 30"x9.75 now with no lift. If you could not tell I am new at this.
holkster is offline
post #4 of 10 Old 02-27-2002, 01:08 AM
igofshn
Locked @ both ends
igofshn's Avatar
It probaby came stock with 205 or 215/75.
igofshn is offline
post #5 of 10 Old 02-27-2002, 01:09 AM Thread Starter
holkster
I bout it used with 30"x9.75 Goodyears on it.
holkster is offline
post #6 of 10 Old 02-27-2002, 07:45 PM
IBjeepN4mud
3.07 and 33's will give you poor gas mileage a loss of power and forget 5th gear it is gone. I mean to that is 4th will be your OD and 5th is too low RPM unless you drive 80 MPH.
The perfect gear is 4.56 and this will correct your milage and power loss. You will even get your 5th gear back.
If you read up this is the most common gear ratio.
1st jeep 83 cj8 scrambler
2nd jeep 92 yj wrangler
3rd jeep 88 yj wrangler
4th jeep ??????????? Still looking
IBjeepN4mud is offline
post #7 of 10 Old 02-27-2002, 09:28 PM Thread Starter
holkster
I am going to wait on the tires and regear to probably 4.56 or 4.10
holkster is offline
post #8 of 10 Old 02-27-2002, 10:15 PM
Chumpbusta
3.07 is an odd gear....I have a 6cyl with the roiginal gears (3.73). I run 35x12.5x15's. My jeep runs fine. I did't lose 5th, but pretty damn close. If the wind blows, I have to down shift.
I have done ALOT of investigative work, and I'll agree with one of the other guys...4.56 is the most preferred gearing. However, since ur only running 33's, you might be able to pick up those 4.10s that came with ALL of the 4 banger YJ's....sure you can find in any junkyard.
3rd Jeep...'95 YJ 6 Cyl
4" Superlift, 1.5" shackles, 1" body lift
35x12.5x15 MT Baja Claws
Warn XDi9000 winch, full spray in liner
and all the doodads you need to do it right!
Chumpbusta is offline
post #9 of 10 Old 02-28-2002, 12:16 AM
bobznew
This is the exact setup I run, and it's really not so bad. Course, I don't do any rock-crawling either!
'97 ZJ, 4.0L, Gibson Cat-back system, Daily Driver
'95 YJ, 4.0L, 3.5" BDS suspension lift, Boomerang Shackles, BDS Shocks, 33x12.50 TSL's, Lock-Rite in rear, No-Slip up front, Posi-lok, Warn XD9000i winch, and a ton of dried Mississippi mud!
bobznew is offline
post #10 of 10 Old 02-28-2002, 05:46 AM
Big92Jeep
I run 33" tires with 4:10 gears. I had a dana 35 with 4:56 gears at one time. I thought the RPMs where a little high on the road. So when I re-geared fron't and rear I went with 4:10s. I think it's the perfect ratio for 50% road/ 50% trail.
Just my 2ó
~RýCK
2008 Unlimited Rubicon
"The weather is here, I wish you were beautiful"
Big92Jeep is offline
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 07:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 07:40 AM
how to tell gear ratio by the ring gear YJscott2 YJ Wrangler Technical Forum 6 01-10-2010 08:30 PM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 10:52 AM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 10:52 AM
