Gear ratio. - JeepForum.com
post #1 of 12 Old 08-30-2011, 04:37 PM Thread Starter
Tpeal9
Gear ratio.
I was replacing my universal joints today and decided to try and figure out the gear ratio. I lifted up the rear end and marked the tire and the drive shaft on the side about the 3 oclock position on the shaft and the 1 o clock position on the tire. I have 33x12.50 R15 tires. I was expecting 3.55 gears. But instead of rotating 3 1/2 times the drive shaft only rotated 1 1/2. Did I do this wrong? Or can someone shine some light on the subject for me thanks.
Tpeal9 is offline
post #2 of 12 Old 08-30-2011, 05:49 PM
clarkjdg
clarkjdg's Avatar
This you can figure it at http://www.grimmjeeper.com/gears.html
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #3 of 12 Old 08-30-2011, 05:55 PM
zeus87gn
1987 YJ Wrangler
Just lift up one tire and then do it again.
The whole rear diff in the air threw off your numbers.
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #4 of 12 Old 08-30-2011, 09:43 PM Thread Starter
Tpeal9
Okay I'll try this out and see. Thanks!
Tpeal9 is offline
post #5 of 12 Old 08-31-2011, 06:34 PM
zeus87gn
1987 YJ Wrangler
any luck?
zeus87gn is offline
post #6 of 12 Old 09-01-2011, 09:58 AM Thread Starter
Tpeal9
Not yet I'm pretty busy at work I'll end up doing it Friday afternoon. I'll let you know
Tpeal9 is offline
post #7 of 12 Old 09-01-2011, 03:50 PM
monkey710
I am assuming there is no tag on the rear axle case? Believe it or not, but the 89 YJ I picked up still had the original tag in it. As long as no one went in to adjust the ratio, I would expect it to still be there.
monkey710 is offline
post #8 of 12 Old 09-01-2011, 03:56 PM
wahabooo
Yes
wahabooo is offline
post #9 of 12 Old 09-03-2011, 08:16 PM Thread Starter
Tpeal9
I didn't see a tag. But the ratio is the same with both tires off the ground and only one off the ground. 1 tire rotation= 1 1/2 drive shaft turn. It can't be right for the gear ratio to be that high. Does it matter if it's in 1st gear? Ive had it in neutral while doing it.
Tpeal9 is offline
post #10 of 12 Old 09-03-2011, 08:42 PM
Mark05059
try again... mark one of the ujoint yoke bolts first.. then mark your tire at the 12 oclock position. Then rotate the tire while watching the yoke.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #11 of 12 Old 09-03-2011, 09:00 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Pull the carrier out, count the teeth on the ring gear and divide that by the teeth on the pinion gear. It's a D35 you'll be tearing it apart soon enough. Just get some practice now while you can .
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #12 of 12 Old 09-06-2011, 08:44 AM Thread Starter
Tpeal9
Yeah I'm going to buy Dana 44's with 4.56 gears and an ARB locker whenever I save up the $3000
Tpeal9 is offline
