Quantcast Gear Question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Gear Question
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 04-03-2009, 04:39 PM   #1
lilblack89jeep
Gear Question
okay, my wrangler has a 7.5in lift with 35x12.50x15 mud terrains on it with 4.10 gears in it which kinda stucks im asking what gears should i run 4.56 or 4.88 i mite change the tires out to 36x14.50x15 but not any bigger then that.
89 YJ Wrangler 7in lift 35 mt's and much more
97 Trans Am M6 With Bolt On's
01 GSX-R 600
lilblack89jeep is offline   Reply With Quote
Old 04-03-2009, 04:41 PM   #2
TheRealOldjeep
4.88's.
7.5" of lift - seriously?
Chuck P
94 YJ 2.5L/AW4
http://www.jeepforum.com/forum/f22/94-yj-649943/ Build Thread
www.oldjeep.com My site
www.mntrailriders.org My Club
TheRealOldjeep is offline   Reply With Quote
Old 04-03-2009, 04:47 PM   #3
MLJeeper
MLJeeper's Avatar
Originally Posted by TheRealOldjeep View Post
4.88's.
I agree. TROJ hes talking total amount from looking at his rig info.
Your limited slip differential sucks.
MLJeeper is offline   Reply With Quote
Old 04-03-2009, 04:51 PM   #4
KraZeDav
easily amused
KraZeDav's Avatar
Is that just for Mall cruisin' and pickin' up girls
Hope you have some spare axles. That stock D35 with that combo you're gonna snap on. Unless of coarse you're just cruisin' the malls.
Post a picture
. . . . . ----o00--()--00o----. . . . .
KraZeDav is offline   Reply With Quote
Old 04-04-2009, 02:22 AM   #5
lilblack89jeep
yes it has 7.5 in lift why ? it had 4.5 leaf springs,2in shackles,1in body, and why would i brake axles with 35's ? my old jeep also had 35s and went wheeling almost every other day ( mud,hills,rocks) never had a problem before and i know somone who is an owner of a custom jeep shop and he even said as long as i dont go to 37 i will be fine with stock axles.
01 GSX-R 600
Old 04-04-2009, 03:14 AM   #6
ImpactFabWorks
I have to disagree with your jeep guy. A friend of mine is on 35" tires and he broke 3 axle shafts before swapping to an 8.8. And I have broke 1 axle shaft on 31" tires. The Dana 35 just can't handle that much tire
ImpactFabWorks is offline   Reply With Quote
Old 04-04-2009, 03:29 AM   #7
scottieboy
1987 YJ Wrangler
Post a picture
he meant dana 35 axles, unless u get stronger axles u do have a chance of snapping them
scottieboy is offline   Reply With Quote
Old 04-04-2009, 10:04 AM   #8
RockWoRM
don't fear the Jeeper
RockWoRM's Avatar
4.88's without a doubt. I have 4.56's and 35's and its 'OK'. Closer to stock ratio, so I would like to be lower.
As far as tha axles... I was "luckey" for a few years with a turdy 5. If you decide to put $$$ towards gearing your stock axles, thats your choise, but IMHO that same money could be put towards something a little beefier. As far as your 'Jeep guy', there does seem to be a little bit of fact that non C-clip turdy 5's seem to hold up better than do clips, if indeed that is what you have... but its still a D35.
WRM
'92 YJ, 4.0, 5sp, 8.8 w/ 4.56's locked F&R, Teralow 4-1, HD SYE, BDS 5" SUA lifted on 35 MTR's. PSE front trail cage kit, 1ton TRE flip, 1"shackles, 1"BL, 1" MM. <><
RockWoRM is offline   Reply With Quote
Glock Forum
