Gear oil leak after drive - JeepForum.com
post #1 of 11 Old 01-01-2012, 09:24 AM Thread Starter
05ChrisTJ
I drove the Yj 100miles non stop (it's longest non stop journey since I have owned it) when I stoped the rear dif was covered in gear oil it had also sprayed all over the gas tank skid I checked the oil level in the dif and it was full. But where did all this oil come from? I have had the jeep for a little bit put about 3k miles on it and not a problem. All 100 miles were freeway at about 65-70 mph.
05ChrisTJ is offline
post #2 of 11 Old 01-01-2012, 09:32 AM
nembudonna
Check the trans. Not sure where it came from,but it came from somewhere.
nembudonna is offline
post #3 of 11 Old 01-01-2012, 09:57 AM Thread Starter
05ChrisTJ
I'll check but there is no signs of any oil in front of the where the driveshaft enters the rear dif
post #4 of 11 Old 01-01-2012, 10:12 AM
nembudonna
I've had rearend seals leak but they didn't spray oil every where. There would just be oil on the bottom of the rearend. Is there oil on the front of the trans or differ?
post #5 of 11 Old 01-01-2012, 11:13 AM
wildchild
Check your diff vent line. If it is plugged when you drive long distance fluid heats up and creates pressure thus pushing gear oil out the seals
wildchild is offline
post #6 of 11 Old 01-01-2012, 11:44 AM Thread Starter
05ChrisTJ
This must be it cause I don't see a vent line on the diff at all. Do I just drill and tap a nipple? Just like you would for an air locker?
post #7 of 11 Old 01-01-2012, 11:59 AM
NHfireLJ
NHfireLJ's Avatar
Vent line is on the driver side of the axle tubes, not on the pumpkin...runs up behind the fuel fill..
check again...
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #8 of 11 Old 01-01-2012, 12:03 PM
NHfireLJ
NHfireLJ's Avatar
You said it was full when you checked..ie when you pulled the fill plug it poured dripped out? or did you have to stick your finger in to feel the level...
Although hard to do it can be over filled...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #9 of 11 Old 01-01-2012, 12:23 PM Thread Starter
05ChrisTJ
I'll go out and check after writeing this. when I pulled the plug the oil was level with the bottom of the plug hole.
post #10 of 11 Old 01-01-2012, 01:05 PM Thread Starter
05ChrisTJ
dont know why my post didnt post but I'm not writing another novel. pretty much I think i fixed it and I'm going to drive it back home tomorrow and I'll keep you updated.
post #11 of 11 Old 01-01-2012, 01:49 PM
wildchild
The vent line usually goes right up the middle of the brake line T where the flex line connects to the rear diff. Take it off the frame, there is a plastic cap on it. This gets plugged with mud and crud. Clean it and blow through it to make sure it is clear
Leak where drive shaft goes into differential?? squib518 TJ Wrangler Technical Forum 10 11-08-2010 03:15 PM
fluid leak...Tranny or Drive shaft cjapgar YJ Wrangler Technical Forum 1 12-08-2009 12:09 PM
Differential Leak at Drive Shaft j2roch TJ Wrangler Technical Forum 10 07-15-2009 10:23 AM
My jeep took a leak in the drive way crxman91 TJ Wrangler Technical Forum 10 11-20-2005 09:23 PM
leak from rear drive shaft mhmmofr0 YJ Wrangler Technical Forum 5 09-01-2003 06:36 AM
