Gear ID - JeepForum.com
post #1 of 4 Old 05-06-2001, 04:57 PM Thread Starter
rayray
rayray's Avatar
Gear ID
Does anyone know of a chart for Dana/spicer gears for that I can use to cross-ref part numbers. I just pulled my pinion gear and I want to verify the gear ratio. Stamped on the pinion shaft is the following.
Dana 40362 D3
RB V1L151 41 9
This is out of a high pinion dana 30 axle (YJ front axle). Thanks.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #2 of 4 Old 05-06-2001, 07:14 PM Thread Starter
rayray
rayray's Avatar
My question was answered on another list, so I thought I would share this little tid bit.
From this number, RB V1L151 41 9. Divide 41/9, and your number comes out to 4.55555555555555555555555555555556, or in other words 4.56. It just goes to show you learn something new every day . Anyway, I thought it was neat.
rayray
rayray is offline
post #3 of 4 Old 05-07-2001, 04:03 AM
horatio102
Interesting. Was 4.56 the factory ratio? I found this little map of stampings for the Dana 30
horatio102 is offline
post #4 of 4 Old 05-07-2001, 10:52 AM Thread Starter
rayray
rayray's Avatar
The factory ratio was 4.10 for the 4 cylinder models and 3.07 for the 6er's. I have seen some 95 6er's that had ratio tags stamped with 3.55 although I've never had anyone confirm if they came with that low of a gear. Could be a good little topic
rayray
rayray is offline
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 07:58 PM
Opinion Wanted On Gear Pattern -- New Gear Setup Jim93YJ YJ Wrangler Technical Forum 9 01-16-2011 01:14 PM
Dana 44 rubicon rear limited slip gear oil, synthetic or regular gear oil what weight rutacon05 TJ Wrangler Technical Forum 6 09-16-2009 09:53 AM
New Gear Break In..When to Do Initial Gear Lube Change?? Jim93YJ YJ Wrangler Technical Forum 8 10-14-2008 08:59 PM
Spider Gear Missing a Tooth After Re-Gear Break-in Period beertinted TJ Wrangler Technical Forum 2 06-20-2007 02:34 PM
