gear change with issues - JeepForum.com
post #1 of 12 Old 09-15-2013, 07:57 PM Thread Starter
disposablehero
I was in the middle of changing from the 3.55's to 4.10's. The previous owner used a spring pin instead of the bolt to hold the pin inside the carrier. So I need to figure out how to get it out of there. Any ideas?
Question 2. I've been getting mixed replys from people. I have 3.55's right now and can't get a straight answer. Will the stock carrier fit the 4.10's? Or will I need to replace those too? My diff. Is LSD too. If that matters.
89yj- just getting started.
07.5 ram 2500 6.7 cummins. 13.6@98.6 1/4 on 35" nittos. Sold and sad about it
07 triumph speed triple 1050cc. Roulette Green monster
12 Sonata hybrid hippie car, MPG all day.
06 sierra 2500hd 6.6. On the way to running 11's.
disposablehero is offline
post #2 of 12 Old 09-15-2013, 08:23 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Yes and no. The Dana 35 is 3.55 and up and the Dana 30 is 3.73 and up.
Pic of the problem?
Luck Favours The Prepared
Anticanman is offline
post #3 of 12 Old 09-15-2013, 08:31 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
He means a roll pin, that holds the cross shaft in the carrier.
I cut the tip off of an old screwdriver to push it out from the access hole on the side by the ring gear bolt heads.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 12 Old 09-15-2013, 08:50 PM Thread Starter
disposablehero
So the 30 will be the problem child. OK. I'll try to source a 30 carrier. I'll more than likely just go open carrier. Poor people problems.
This pin is really in there. I tried an Allen wrench and hammer with no luck. I didn't hit very hard for fear of bending the end over the spring pin.
post #5 of 12 Old 09-15-2013, 08:55 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
So you know - that roll pin is a standard piece for that carrier since its not threaded for a bolt.
Joe Dillard is offline
post #6 of 12 Old 09-15-2013, 08:58 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Find a screwdriver that has a shank size pretty close to the size of the hole (on the ring gear bolt head side of the carrier) and cut the tip off. Stick it in there & beat on it, don't worry about the pin, it'll be fine.
Max
Mean Max is offline
post #7 of 12 Old 09-15-2013, 08:59 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Definitely!
Howdy Joe!
Max
Mean Max is offline
post #8 of 12 Old 09-15-2013, 09:02 PM
Joe Dillard
Hey there Max. Good do see you chime in here & share your wealth of knowledge.
post #9 of 12 Old 09-15-2013, 09:09 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
The shop is incredibly busy, and I really have very little free time anymore. However, who wouldn't want to rip Jeeps apart & put 'em back together all day?
Max
Mean Max is offline
post #10 of 12 Old 09-15-2013, 09:12 PM
Joe Dillard
Max
That's what I'm doing these days too. Matter of fact....we worked today.
post #11 of 12 Old 09-15-2013, 09:24 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Nice!
It's amazing how many hack jobs are out there! I know you must see them all the time too. Tomorrow, I start cutting the skid plate off of a CJ-8 Scrambler. Yep, somebody welded it on.......
Max
Mean Max is offline
post #12 of 12 Old 09-15-2013, 10:14 PM Thread Starter
disposablehero
Right on. Thanks for the help fellas.
