-   -   gear change with issues (http://www.jeepforum.com/forum/f12/gear-change-issues-1590041/)
disposablehero 09-15-2013 07:57 PM
I was in the middle of changing from the 3.55's to 4.10's. The previous owner used a spring pin instead of the bolt to hold the pin inside the carrier. So I need to figure out how to get it out of there. Any ideas?
Question 2. I've been getting mixed replys from people. I have 3.55's right now and can't get a straight answer. Will the stock carrier fit the 4.10's? Or will I need to replace those too? My diff. Is LSD too. If that matters.
Anticanman 09-15-2013 08:23 PM
Yes and no. The Dana 35 is 3.55 and up and the Dana 30 is 3.73 and up.
Pic of the problem?
Mean Max 09-15-2013 08:31 PM
He means a roll pin, that holds the cross shaft in the carrier.
I cut the tip off of an old screwdriver to push it out from the access hole on the side by the ring gear bolt heads.
Max
disposablehero 09-15-2013 08:50 PM
So the 30 will be the problem child. OK. I'll try to source a 30 carrier. I'll more than likely just go open carrier. Poor people problems.
This pin is really in there. I tried an Allen wrench and hammer with no luck. I didn't hit very hard for fear of bending the end over the spring pin.
Joe Dillard 09-15-2013 08:55 PM
So you know - that roll pin is a standard piece for that carrier since its not threaded for a bolt.
Mean Max 09-15-2013 08:58 PM
Find a screwdriver that has a shank size pretty close to the size of the hole (on the ring gear bolt head side of the carrier) and cut the tip off. Stick it in there & beat on it, don't worry about the pin, it'll be fine.
Max
Mean Max 09-15-2013 08:59 PM
Definitely!
Howdy Joe!
Max
Joe Dillard 09-15-2013 09:02 PM
Hey there Max. :wave: Good do see you chime in here & share your wealth of knowledge.
Mean Max 09-15-2013 09:09 PM
The shop is incredibly busy, and I really have very little free time anymore. However, who wouldn't want to rip Jeeps apart & put 'em back together all day?
Max
Joe Dillard 09-15-2013 09:12 PM
Max
That's what I'm doing these days too. :tea: Matter of fact....we worked today. :eek:
Mean Max 09-15-2013 09:24 PM
Nice!
It's amazing how many hack jobs are out there! I know you must see them all the time too. Tomorrow, I start cutting the skid plate off of a CJ-8 Scrambler. Yep, somebody welded it on.......
Max
disposablehero 09-15-2013 10:14 PM
Right on. Thanks for the help fellas.
The time now is 01:13 AM.
