gc disc brake swap - JeepForum.com
post #1 of 5 Old 01-23-2013, 10:39 AM Thread Starter
kjg26
kjg26's Avatar
gc disc brake swap
I know many will say it is a waste of time and money to swap an Grand Cherokee disc brakes on to a Dana 35. Well I did anyway.
After the swap I was not impressed with the braking power. This swap was into my 93 YJ. I decided to upgrade my master cylinder brake booster and proportioning valve. The master and booster came from a 6 cyl 95 YJ dual diaphragm. The prop valve came from a 97 grand cherokee with rear discs.
The hardest part was finding the 95 master and booster then finding the adapters from the master to the prop valve.
I used a total of 2 adapter lines and 2 adapter fittings.
I am amazed at the stopping ability now. Since I did the upgrade of the prop valve at the same time I cant say which played a bigger role or if its a combination. Either way I'm very happy. Now onto drive line angles
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 5 Old 01-23-2013, 12:49 PM
Mark05059
let us know when your d35 drops a stink on you
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 5 Old 01-23-2013, 12:50 PM Thread Starter
kjg26
kjg26's Avatar
10/4. Will do.
kjg26 is offline
post #4 of 5 Old 01-23-2013, 01:03 PM
SeanB95YJ
would it have been easier to get all the components (MC/booster/prop valve) from the GC too? or is it too far off to bolt up without major mods?
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #5 of 5 Old 01-23-2013, 01:07 PM Thread Starter
kjg26
kjg26's Avatar
I have no idea a about the gc master and booster. In all my research it never came up. And just for the record, the above lines and adapters will adapt a 95 master to stock prop valve as well.
kjg26 is offline
