Gauge's do not work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Gauge's do not work
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder Brawler MID Front Bumper for JKSuper Low Prices on TJ Bumpers and $399.95 Tire Carriers!
Unread 06-01-2004, 09:54 AM   #1
JT29
Gauge's do not work
I need some help, all the gauge's stoped working. One morining they all worked, that affternoon they did not. Everything else works, even the lights on the insterment panel but not the gauges. If anyone could help me that would be great.
JT29 is offline   Reply With Quote
Unread 06-01-2004, 11:04 AM   #2
Tshark299
1987 YJ Wrangler
To start, I would check all the fuses to make sure none are blown, assuming you haven't done that already.
'87 YJ Laredo - 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
'95 XJ - Donated drive train to the YJ, Parting the rest out
'51 CJ-3A - Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline   Reply With Quote
Unread 06-01-2004, 05:02 PM   #3
DavesMatthew
Crawl up under your jeep, look above your transfercase skid plate, there should be a tied bunch of wires. They could have wound up on top of your exhuast, melting them. These are your sensor wires. It also could be fuses, but I dont think you would lose all your guages becuase of this.
'95 4 cylinder
6" Rough Country Suspension
33x12.5 BFG AT's
Tuffy overhead console
Hella lights
SmittyBilt Backpack Rack
DavesMatthew is offline   Reply With Quote
Unread 06-02-2004, 09:39 AM   #4
Tshark299
1987 YJ Wrangler
Which gauge sensors would have wires running above the skid plate? I've dropped mine a few times before and didn't see any wires up there.
The water temp. and oil press. gauges have sensors on the engine block, and therefore would have no reason to run under the Jeep, but rather through the wireing harness that passes through the firewall. The fuel gauge wire runs along the inside edge of the driver's side along with the taillight wires and whatnot. The volt meter doesn't have a sensor.
Unread 06-02-2004, 01:21 PM   #5
ugajeepgirl
I'm thinking its a blown fuse. I've blown two fuses since I've owned my YJ, and everytime, all the gauges went out, save for the speedo and clock.
Silly boys, Jeeps are for girls ;)
A girl and her Jeep: it's a beautiful thing :)
ugajeepgirl is offline   Reply With Quote
