Gauges dead & no reverse lights - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Gauges dead & no reverse lights
Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955XHD Heavy-Duty Hood Latches for JK and TJ available at OcoFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread Yesterday, 10:13 PM   #1
92YJ_Islander
1992 YJ Islander 4.0 5-speed 105k miles
Today when I left for work I noticed none of my gauges, speedo, or tach were working. All still light up when the headlights are on. I came home and tore apart the dash, all to find no issues. I also verified all fuses are still good.
I finally disconnected the battery and let everything reset. Much to my amazement, my gauges worked! Well, for about a minute. The temp and voltage gauges still weren't working. After about 1 minute none were working. I also noticed my reverse lights are no longer working.
Note: This is all happening after attempting to jump start my F150.
Any ideas?
92YJ_Islander is offline   Reply With Quote
Unread Yesterday, 11:25 PM   #2
mike134
Hi Islander,
First, check the fuse again for continuity with an ohm meter, put a different one in there if you have a spare (fuse 9 according to the manual), Sometimes they only get partially damaged which makes it difficult to diagnose...
Next check the voltage at the fuse with a voltmeter with the ignition switch ON. Is it 12 Volts?
mike134 is online now   Reply With Quote
