Gauge Cluster wiring diagram! - JeepForum.com
post #1 of 17 Old 06-14-2009, 01:17 PM Thread Starter
wrestler22491
I need the gauge cluster wiring diagram for a 1990 wrangler YJ and also one for a 1994 YJ gauge cluster. Any help would be great. thanks
wrestler22491 is offline
post #2 of 17 Old 06-14-2009, 01:32 PM
jsawduste
2006 YJ Wrangler
Try this
http://colorado4wheel.com/allmanuals/Jeep/
jsawduste is offline
post #3 of 17 Old 06-15-2009, 03:48 PM
USMC_JeepGuy
Try these.
USMC_JeepGuy is offline
post #4 of 17 Old 06-15-2009, 03:50 PM
USMC_JeepGuy
And these!
post #5 of 17 Old 06-29-2009, 06:39 PM Thread Starter
wrestler22491
thanks, ill give it a try and c how it works
post #6 of 17 Old 08-13-2011, 03:01 PM
Cohz
I'd like to open this forum again. I have the exact same problem. I have a 1990 Jeep Wrangler and purchased a 1994 gauge cluster for the fuel, water etc.. I used the wiring diagrams above and it didn't work. Only the lights would come on. So I'm guessing illumination and ground are correct. This is what I did:
1990 wires to 1994 gauge
pin 1 coolant to pin 11 coolant (diagram says pin 12, no wires coming out of plug)
pin 2 gauge fuse to pin 2 ignition feed
pin 3 ground to pin 13 and pin 1
pin 4 fuel to pin 6
pin 6 oil pressure to pin 9
pin 10 illumination to pin 7
pin 12 illumination to pin 8
Cohz is offline
post #7 of 17 Old 08-13-2011, 05:37 PM
wendell
1987 YJ Wrangler
They changed the wiring in 91, it might be easier to get the proper cluster off ebay for 87-90. They allways have them on there.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #8 of 17 Old 08-14-2011, 09:26 PM
Cohz
I think you're right.
Cohz is offline
post #9 of 17 Old 08-15-2011, 10:06 AM
Que89YJ
Another flash back post. Here is the diagram you need in this post:
http://www.jeepforum.com/forum/f12/j...oblems-346403/
Que89YJ is online now
post #10 of 17 Old 05-08-2012, 05:22 PM
tommbstone
are these wire diagrams good for an 89 jeep wrangler instrument cluster?
thx guys
tommbstone is offline
post #11 of 17 Old 05-08-2012, 06:03 PM
Que89YJ
It looks like it and it's for an 89 so yes.
Fault codes:
Mean Max pics of everything:
No Start:
post #12 of 17 Old 05-09-2012, 08:12 AM
tommbstone
Thank you sir, trying to re-wire my dash and I wanted to reuse most of orginal harnes like for fule power ground ligt dimmer etc I could run new wire for oil and water IF i had to but If I could just change the sensors and use same wires its easier.
Thx again.
post #13 of 17 Old 06-03-2012, 08:28 AM
CBinDC
I had a custom dash made and am putting in autometers. I'm just going to cut the wiring harness and add new wire to the existing. What gauge should I use?
CBinDC is offline
post #14 of 17 Old 06-04-2012, 01:04 PM
Que89YJ
What guage? Are you talking about the wire guage size? If you are the guages can be run with 18 ga. but the lights for the guages depend on the current draw of the bulbs and how you wire it. I would recommend 14 Guage if they are incandensent bulbs.
post #15 of 17 Old 06-04-2012, 02:44 PM
CBinDC
Autometers (mechanical). While I was browsing a Molex 12 pin quick disconnect (only takes up to 18 gauge wire) and wiring at NAPA this a.m. I realized that the stock wire for gauges is in fact 18.
CBinDC is offline
YJ (88) Gauge Wiring Diagram fh2level YJ Wrangler Technical Forum 3 05-07-2007 06:09 PM
straight-wiring of gauge cluster oc92 YJ Wrangler Technical Forum 2 02-26-2007 06:39 AM
gauge cluster?!?!?!?!?!?! tcaz10 YJ Wrangler Technical Forum 10 01-31-2007 07:39 AM
gauge cluster wiring Ares YJ Wrangler Technical Forum 4 12-10-2006 04:54 AM
Need sending unit to gauge wiring diagram for 88YJ b1web YJ Wrangler Technical Forum 1 03-30-2004 07:09 PM
