Gauge Cluster Help - JeepForum.com
post #1 of 21 Old 09-07-2005, 11:46 AM Thread Starter
daynknight
Gauge Cluster Help
Bought used gauge cluster off EBAY. The seller said it was for a yj 87-95. The wiring harness is pin type . My "88" yj has a ribbon type connection that connects directly to the board. Can this be adapted to work? The pin one has 13 pins and only 12 contacts on the ribbon connector. Or do you know were I can get a cheap gauge cluster . have been to all the bone yards near by , none of them have any wranglers . My gauge cluster has 5 gauges ,If a picture is needed of the connector e-mail me for one.
Thanks for any help you can give
daynknight is offline
post #2 of 21 Old 09-07-2005, 12:03 PM
wolf3902
What is the part number on the cluster you're replacing, is it the same as the newer one?
I may have one... let me know the P/N number and I'll check for you.
I needed a speed/tach cluster and the yard sold me both since the yard they got it from sent both.
Also, where are you located?
My junk yard didn't have any Wranglers, but they got on the computer and found one...took minutes. and a day to ship.
'93 YJ 2.5 Jasper; 5 speed
All stock, waiting to be reborn.
6/19/05 ...2" BDS suspension lift...the rebirth has begun!!!
ONE NATION, UNDER G O D
Support It, or Leave It!
wolf3902 is offline
post #3 of 21 Old 09-07-2005, 12:20 PM Thread Starter
daynknight
Gauge cluster
Wolf3902 ,
That is part of our problem ,the old one does not have a part # on it. It has only one # on the circuit brd and one on the plastic housing , those #'s are (circuit brd # VDO 3045001461 and the housing # is VDO 3024001253) The one we bought off of ebay is Chrysler Part # 56004888 . this one does not fit our 88 yj. If you email me i would be able to send you pic's of what the old one it looks like.
thanks for your help
post #4 of 21 Old 09-07-2005, 12:29 PM
wolf3902
The one I have is the same as the one you got off e-bay. #56008888
13 pins.
I think a picture would help someone here to be able to help you.
Maybe you could call a dealer and get the Crysler part number at least.
The dealer wanted $360.00 for my tach/speed cluster so I went to the junk yards.
Send me pics and I can post them for you tomorrow morning. I'm leaving here for the evening and won't be back on till then. Or someone else can today.
sent you a PM
wolf3902 is offline
post #5 of 21 Old 09-07-2005, 01:05 PM Thread Starter
daynknight
Gauge Cluster
Wolf3902,
Got the PM , sent you pictures.
thanks again for all the help,
post #6 of 21 Old 09-08-2005, 06:58 AM
wolf3902
Posting pics for daynknight.
I'm clueless about these gauges. Hope someone can help.
wolf3902 is offline
post #7 of 21 Old 09-08-2005, 09:54 AM Thread Starter
daynknight
Gauges
wolf3902,
thanks for all the help. as you can see I really do need it.
post #8 of 21 Old 09-08-2005, 10:01 AM
Wif
Wif's Avatar
I'd watch out for the oil pressure gauge tho .. looks like it's bent the needle from pegging so hard ..
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
post #9 of 21 Old 09-08-2005, 01:31 PM
Raindem
Originally Posted by daynknight
The seller said it was for a yj 87-95...
Not true. In '92 or '93 the analog clock was removed the 4x4 indicator moved to the left hand side of the cluster. Other guages changed position so I'm sure the connections are different.
If it ain't broke... break it.
Raindem is offline
post #10 of 21 Old 09-08-2005, 01:54 PM
new to this
my 91 has the guages in diferent place than the one shown
temp on left then fuel then clock than oil then volts
mine all work except temp
new to this is offline
post #11 of 21 Old 09-08-2005, 02:09 PM
89YJmoneypit
KMG365
89YJmoneypit's Avatar
That's exactly the same as my 89,right down to the temp guage not working
89 YJ
Transplanted '99 4.0, AX-15, NP231
Red Jeep club #8
Now belongs to my daughter.
97 ZJ Laredo
4.0, 42re, NP242
R.I.P.
Marseilles Fire Dept:
89YJmoneypit is offline
post #12 of 21 Old 09-08-2005, 02:09 PM
Wif
Wif's Avatar
check the sender .. ground the wire to the head (with the ign on) and check to see if the gauge goes up to hot .. if so replace the sender ..
Formally 88Jeepster
Who's in front ?
Wif is offline
post #13 of 21 Old 09-08-2005, 02:47 PM Thread Starter
daynknight
Where is the sender located????? Is there a way to test the gauge with out it being hooked to the circuit board. The circuit board it in bad shape.
post #14 of 21 Old 09-08-2005, 02:48 PM
jeepnguns
jeepnguns's Avatar
My 88 has the same positions with a wire ribbon connection in the back. Except my temp fuel and clock do not work.
88 Wrangler
350 Chevy engine vortec heads Holley Pro-Jection
Ford T-18 Tranny
Dana 44s Detroits w/ 5.89s
38" Swamper SX
Lots of other random things and dents
jeepnguns is offline
post #15 of 21 Old 09-10-2005, 11:28 AM
wolf3902
daynknight,
Did you get the gauge issue resolved yet?
wolf3902 is offline
Gauge cluster trapman TJ Wrangler Technical Forum 19 05-07-2015 01:03 PM
How to the gauge cluster? jagarcia82 YJ Wrangler Technical Forum 3 03-14-2010 09:37 PM
Gauge Cluster Changes 89MustangGX TJ Wrangler Technical Forum 5 11-10-2007 11:46 PM
gauge cluster?!?!?!?!?!?! tcaz10 YJ Wrangler Technical Forum 10 01-31-2007 06:39 AM
Used Gauge Cluster qteasy TJ Wrangler Technical Forum 1 02-07-2004 02:07 PM
