gauge cluster and electric fan not working??? - JeepForum.com
post #1 of 1 Old 04-25-2009, 03:38 PM Thread Starter
Billy13
After i wired up a set of lightforce lights the other day i noticed today that my electric fan was not coming on with the ignition like it had been. i checked all the fuses both in the jeep and under the hood. i had pulled the one bad (dome light) fuse i found out and started off to the parts store for some fuses and then noticed that none of my gauges were working. i replaced the bad fuse and still no fan or workin gauges. even the lights on the gages are not workin. my buddy did arc a power wire for a split second during the light install. i thought that would have just blown a fuse though. oh i didnt mention the jeep still starts fine just no fan and no working gauge cluster. any suggestions of what to do next?
IF YOU LIKE METAL CHECK OUT MY BAND!
Billy13 is offline
89 YJ Gauge Cluster CheapSunglasses YJ Wrangler Technical Forum 14 06-07-2010 07:38 AM
interior lights not working after gauge cluster LED install mJUSTINm TJ Wrangler Technical Forum 4 02-10-2010 06:51 PM
Need a new gauge cluster for 88 yj DP88yj YJ Wrangler Technical Forum 3 12-09-2009 03:16 PM
gauge cluster gfritzges TJ Wrangler Technical Forum 1 03-22-2007 09:17 PM
YJ Gauge cluster microtek YJ Wrangler Technical Forum 3 07-26-2002 02:09 PM
