Gauge cluster bulbs - JeepForum.com
post #1 of 11 Old 05-06-2008, 12:18 PM Thread Starter
Mr.Alllthat
Gauge cluster bulbs
Does anyone know where I can find the light bulb holders that screw into the back of the gauge clusters. The jeep I have was a parts jeep and they are all missing for whatever reason. Is this a dealer part or might someone sell them separate. I noticed they are similar to the ones in my chevelle gauges maybe it's something I can find from a vendor.
Edit:
I there are 8 large bulb holders and 11 small ones for the turn signals et cetera. http://www.superbrightleds.com/cgi-b...1.3170&next=50
that is a link to 3 types of them that super bright leds sells, but what ones go where?
04 WJ Limited 4.7 v8, Quadradrive, Black on Black fully loaded DD
Mr.Alllthat is offline
post #2 of 11 Old 05-06-2008, 01:47 PM
djfred
thats a pretty cool link thanx
i might end up ordering the blue light size 74 bulbs
--Now--
White 92 YJ -- RE 1.5" SOA -- BFG KM2 35x12.50x15 -- D30 (4.88 w/ ARB) -- Ford 8.8 (4.88 w/ ARB)
Sanden OBA
--Future Mod--
Flat Fenders
djfred is offline
post #3 of 11 Old 05-06-2008, 02:01 PM Thread Starter
Mr.Alllthat
any idea what bulbs fit it...there are the big twist lock holders that go around the speedo, tach, and the other 4 gauges. Then there are the smaller twist lock holders that go to the blinkers etc. anyone know which fits which?
I just measured the holes and it looks like the large bulbs are the T1.5-X and the small bulbs for the blinkers etc. are B8.5D-X but i'm not positive.
post #4 of 11 Old 05-06-2008, 02:59 PM
djfred
it is a possibility since you say that now
i think getting the size 74 might be wrong ill
take a look at what size i have spares of when i get home later on tonight
I remember buying a bulb like this before
with the wires bent back like that
--Now--
Sanden OBA
--Future Mod--
Flat Fenders
djfred is offline
post #5 of 11 Old 05-06-2008, 04:12 PM Thread Starter
Mr.Alllthat
the ones i mentioned are the 74 bulb in the twist on holder already, an all in 1 type deal. I am missing those plastic holders so I need them too, I think that bulb is right for at least some of them...194 is what a lot of the actual bulbs are
post #6 of 11 Old 05-08-2008, 11:33 PM
djfred
This is the kinda bulb i used to change the cluster and instrument panel lighting
--Now--
Sanden OBA
--Future Mod--
Flat Fenders
djfred is offline
post #7 of 11 Old 05-09-2008, 02:32 AM
jeepdog5
jeepdog5's Avatar
i just swapped my cluster bulbs to LEDs, DO NOT GET THE ONES I DID. They didn't fit at all and I ended up modding my gluster with a dremel to get them to fit. And because i had to widen the holes so that the new bulbs could fit, it literally rendered those plastic bulb retainers useless and i had to solder the wires from the LED bulbs to the plastic circuit paper on the back of the gauge cluster. A real PIA mod. Now for pics...
jeepdog5 is offline
post #8 of 11 Old 05-09-2008, 09:55 AM
djfred
what size is that ill stay away from it.
--Now--
Sanden OBA
--Future Mod--
Flat Fenders
djfred is offline
post #9 of 11 Old 05-09-2008, 10:14 AM
jeepdog5
jeepdog5's Avatar
these are the ones i used:
921-x12 Wedge Base LED Bulb
921 Type with 12 LEDs, replaces 194/168/912 wedge base car bulbs
Wide 75 degree beam pattern, non-polarized
measures 1.20 inch long by 0.60 inch diameter
jeepdog5 is offline
post #10 of 11 Old 05-09-2008, 11:22 AM
djfred
thanx i will stay away form 921-x12
ima order me some of those color ones now of the 74
--Now--
Sanden OBA
--Future Mod--
Flat Fenders
djfred is offline
post #11 of 11 Old 05-09-2008, 02:40 PM
djfred
Here is a Great Site i found, if you want to know what kinda bulb you have around the car
http://www.sylvania.com/ConsumerProd...lacementGuide/
--Now--
Sanden OBA
--Future Mod--
Flat Fenders
djfred is offline
89 YJ Gauge Cluster CheapSunglasses YJ Wrangler Technical Forum 14 06-07-2010 06:38 AM
Dash cluster bulbs romanella YJ Wrangler Technical Forum 2 08-10-2007 11:51 AM
gauge light bulbs onepunchmickey3 TJ Wrangler Technical Forum 6 12-09-2005 07:25 AM
How Many Bulbs Behind the Gauge Cluster? Tshark299 TJ Wrangler Technical Forum 2 08-31-2004 02:35 PM
light bulbs in the guage cluster? BNovak TJ Wrangler Technical Forum 1 07-28-2004 10:40 PM
