On my '95 YJ, my Gauge Cluster keeps blowing a fuse, like 1 a day. :brickwall I'm getting sick and tired of replacing this damn fuse. any ideas on what might be causing this?
[QUOTE='99xjlimited]I'll give that a shot, thanks[/QUOTE]
Just to note, the reason you disco the batt, is you take a chance at touching that stamped board to the bare metal while removing it. TRUST ME, it is a light show.
[QUOTE='99xjlimited]I was wondering about that, thanks. I'll take a look at it this weekend. If that is it, what can I do to fix it?[/QUOTE]
Some have soldered where the circuit board is bad, most disable the gauge that is getting the short. If it's the whole thing, your looking at replacing the entire gauge cluster. That is gonna be fun unless you can find one used. The dealership wants over $70 just for the stamped circuit.
If your looking at a whole replacement, look into autometer gauges.
BUT, check the small stuff first, sorry for the tangent.
It could be a few things. Are you blowing fuse 9? If so Buzzer, gauges, warning lights, relays and backup lights are on that circuit. When you pull the cluster and don't see anything obvious you can add a few inline fuses on those items listed above - light blue wire. When something shorts to ground the blown fuse in line should point you in the correct direction for the problem.
Let me ask, are the guages going out or just the lights for them? If just the lights check the illumination wire for the radio.
Even with the fuse fixed??? Check the backup bulbs and check for rust inside the tail light housings. If the backup lights are good and ground is good, the next step is to start tracing what else is on that circuit.
Well I completely disassembled my gauge cluster and the wiring harness this weekend and slowly put everything back, checking it as I went. When I was done, no more blown fuses and all seems to be working. Oh well!!!
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
