Gauge - Battery or Alternator? - JeepForum.com
post #1 of 4 Old 05-22-2001, 06:08 PM Thread Starter
ncmts
Hope this is not a stupid question, but does the system's electrical gauge measure the level of charge in the battery or what the alternator is putting out? I just noticed the gauge has dropped to just above the red zone at 8 volts.
thanks,
ncmts is offline
post #2 of 4 Old 05-23-2001, 09:03 AM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
I believe it measures the total voltage available, from the battery and what is supplied by the alternator. If your reading 8 volts then either the alternator is not putting anything out or the battery is shot. Try disconnecting the alternator wiring harness and check the guage again. Also, watch the gauge when turning on all electrical accessories.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #3 of 4 Old 05-23-2001, 10:20 PM Thread Starter
ncmts
Thanks FLHT_FXRS_YJ. That sounds like a good idea to isolate the problem.
ncmts
ncmts is offline
post #4 of 4 Old 05-25-2001, 04:09 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I am having a similar issue with my 88 YJ .. the voltage looks good for a while, drops to 1/2 voltage .. and finally drops off the guage .. then pops back up again. I have replaced my alternator and battery .. and no change. I am starting to think it might be a busted up wire or something .. everything else seems to be acting mostly normal.
Laters!
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
YJ losing battery juice while running-battery/alternator good Dannyboy6292 YJ Wrangler Technical Forum 20 01-13-2010 11:54 AM
bad alternator or battery? 91yjeeper TJ Wrangler Technical Forum 13 07-30-2009 10:17 AM
reading 0 on gauge volt battery gauge alecmcmahon TJ Wrangler Technical Forum 13 04-19-2009 03:43 PM
Battery or Alternator? machinehead131 YJ Wrangler Technical Forum 21 11-26-2008 12:45 PM
New battery + working alternator = battery still won't charge pyro9862 YJ Wrangler Technical Forum 7 10-28-2007 08:51 PM
