Quantcast Gathering parts for Axle swap, SOA, and V8 swap... - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Gathering parts for Axle swap, SOA, and V8 swap...
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 06-24-2007, 05:51 PM   #1
tank29
Yeah, It's A Jeep Thing!!
tank29's Avatar
Okay, I have the following items so far and I have only spent $800. This is what I have...
Dana 60 Rear -- Mid 80's 3/4 ton Dodge Van -- $75
Dana 44 Front -- '78-'79 Ford 3/4 ton truck -- FREE
Chevy V8 Vortec 350 -- '98 Chevy 1/2 Pickup -- $600
SM465 Tranny -- Early 80's Chevy Blazer -- $100
NP208C T-Case -- Early 80's Chevy Blazer -- FREE (came with tranny)
Items that I need...
spring perches
lower shock tabs
motor mounts
radiator
Detroit locker for D60
4.88 gears for D60 & D44
drive shafts
I know there's more but I am in a hurry right now...
I did measure the tranny and t-case that I got out of the Blazer and it is about 4' long and the tranny and t-case that is in my 4-banger is about 3' long. Will I have an issue getting the new tranny and t-case to fit with the new V8? It looks like I will end up with a VERY short rear drive shaft. What set-up should I be looking for as far as the rear drive shaft goes? I am having a problem finding a computer that is programmed for the V8. Painless makes a complete wire harness and computer that comes pre-programmed for $1275 plus tax (local parts store). Does anyone know where I could get one or have one programmed for this set-up or if there are any other options out there for I would greatly appreciate it.
I have a new BDS 3.5" lift on it now and a 3" BL. I was hoping to get rid of the BL all together but I think with this t-case I will have to keep it. Am I correct on this since the front drive shaft off of the t-case is about 4"-5" lower than the stock one in the Jeep? Thanks again.
Todd
2007 JK Unlimited "X"
TeraFlex 3" Kit with 4 Arm Flex Kit, TeraFlex HD F & R Adj. Track Bar, Rock Krawler Spring Levelers, Yukon 5.13 Gears, Black Rock Soft 8 Steel Wheels 16x8 (4.25" BS), Cooper Discoverer STT 315/75/16, XRC Rear Bumper w/Tire Swing, Rugged Ridge Front w/Stinger, AEV Snorkel, Cobra 75, KC 130W Slim Lights w/Windshield Mounts, Xenon Flat Fender Flares
tank29 is offline   Reply With Quote
Old 06-24-2007, 06:38 PM   #2
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
idk about you needing to keep the 3" BL, i would think 1" would be plenty, maybe a 1.5" BL if you can find one....3" is just scary.
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>> http://youtube.com/watch?v=nQCIXoBqpc0
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline   Reply With Quote
Old 06-24-2007, 09:17 PM   #3
jeepinMatt
for the t-case you might be able to buy a clocking ring. also i think that rear shaft length will only lead to broken u-joints/shafts w/ a V8 and bad driveline angles. i would think about stretching it. and anything painless sells is over priced but they do all of the work for you and most of it is just a simple plug in.
jeepinMatt is offline   Reply With Quote
Old 06-24-2007, 11:10 PM   #4
tank29
tank29's Avatar
Is there any other places to buy the harness and computer? I know the drive shaft angle will be a bad one but what can I do to correct it? I don't want to stretch it if I don't have too. Thanks.
Todd
Old 06-25-2007, 05:03 PM   #5
tank29
tank29's Avatar
Just bumping to the top for anyone else's ideas and comments. Thanks.
Todd
Old 06-25-2007, 05:22 PM   #6
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
keep in mind your shifter placement will probably dictate where exactly you set the engine mounts but moving it as far forward as possible and using an electric fan would help regain some of your lost rear driveshaft lenth.
have you considered using an np231 with the swap? with a heavy duty chain, super short slip yoke eliminator, and an adapter ring to go with that sm465, you shouldn't have many issues....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
Old 06-25-2007, 05:39 PM   #7
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
i have the 4.3 in my heep, with a 700r4 and 231c hd.
the rear d/shaft is longer than a 4.0/aw4/231j, both slip yoked...
my motor is far enough forward to get to the bellhousing bolts from under the hood, but far enough back to get a sbc in there if the need(want) arrises..
your angles will be fine.
if you dont do a "stretch", get the spring mounts that will allow you to move tha axle back and inch....i used the MORE ones and love them. free stretch front n rear for free...
i also used the painless harness, excellent customer service and backup. worth the $$$ imo.
good luck and keep us posted!
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
leftlanetruckin is offline   Reply With Quote
Old 12-03-2009, 03:42 AM   #8
YJjake12
How did this turn out?
YJjake12 is offline   Reply With Quote
Glock Forum
