Gasket Question - JeepForum.com
post #1 of 8 Old 02-05-2002, 10:57 PM Thread Starter
Johnny'sJeepen
Gasket Question
I have an 89 YJ 258 and Iíve been getting oil leakage around my value cover. Does anybody know for that model if there is a gasket I can get? Or do I need to buy the whole kit with the gasket included> I called the dealer and they quoted me $125 for a new one without Labor. Then I called a jeep place in AZ and they told me $55 without shipping, which will probably be round 40 to 50 bucks. Is this a job that can be installed easily? Any advice is appreciated. Happy Jeepen
J
Johnny'sJeepen is offline
post #2 of 8 Old 02-06-2002, 07:45 AM
glm 87 wrangler
u can use gasket maker but I tried it and it did not work to well for me.I went to advanced auto and told them i needed a cork type gasket for the 258 jeep motor and they had one in stock.So check your local shops first autozone, advance,and napa.But if they dont try www.jeepdoc.com or go to key word krage motorsports same web site and you can order online or call i know they have them.Even with the gasket it may leak a little but the only other solution is the metal replacement.Mine leaks a little but dont bother me.Hope this helps
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 8 Old 02-06-2002, 03:37 PM
4wheel4fun
My 87' came with the plastic valve cover, and always leaked. I replaced it with an aluminum cover from WestSide Preformance. They recommend using RTV vs a gasket. Once I installed my new cover, using RTV, I have for onced sloved my leaking problem. The valve cover is a little costly ($170), however, it's good quality and looks nice. I would go this route before spending $100 bucks on a new gasket.
PS. This valve cover is a simple bolt on. No drilling required, like some after market covers require.
4wheel4fun is offline
post #4 of 8 Old 02-06-2002, 09:05 PM
93YJSahara
try this, says the valve cover gasket is included, http://cgi.ebay.com/ebaymotors/aw-cg...035305&r=0&t=0
93YJSahara is offline
post #5 of 8 Old 02-06-2002, 10:07 PM
CR Perry
Before you spend any money how much is it leaking? My old 258 leaked but it just looked bad and was really no big deal. Adding a quart of oil between oil changes isn't very expensive and it does keep the oil fresher.
95 Wrangler
Rubicon Express 4.5" Lift
CR Perry is offline
post #6 of 8 Old 02-07-2002, 04:52 AM
highway jeeper
I just bought a whole head gasket set from Advanced Auto for around $40.00 for my 87 , 258 and the cover gasket was cork which I had not used.
I replaced the lifters, so I had to remove the valve cover and replace it with the new gasket as part of the process.
Now i have no leaks, but I do keep checking the tightness on the bolts. I do not think you need to spend the kind of money you are talking about.
highway jeeper is offline
post #7 of 8 Old 02-07-2002, 07:23 AM
mike's90YJ
hey they sell complete gaskets sets depending on the job, thru Quadratec and a pretty fair price, most kits include everything need from the Head up to the carb, and no i'm not trying to sell ya their stuff, just thought it may help
90 YJ 4.2 AX-15,TFI Upgrade
Olympic Rock Bumpers
Olympic Tire Swing
2000 TJ Buckets
95YJ RollBar/ 95 YJ Hard Top
KC Daylighters
31/10.50 Goodyears,
Outlaw II 15x8's
mike's90YJ is offline
post #8 of 8 Old 02-07-2002, 09:07 PM Thread Starter
Johnny'sJeepen
Jeepers thanks for the advice. im not sure which route im going to take, but I'll keep you posted. Thanks again. Happy Off Roading
J
4.0 Head Gasket Question MillerTimeTJ TJ Wrangler Technical Forum 10 05-01-2007 12:22 PM
Gasket question rustypjr TJ Wrangler Technical Forum 2 09-18-2006 08:42 AM
Gasket question? madmax79 YJ Wrangler Technical Forum 5 05-16-2006 07:21 AM
Sealing Differential: To gasket or not to gasket, that is my question DrunkPenguin YJ Wrangler Technical Forum 12 06-07-2005 06:41 PM
Oil pan gasket question ColoradoSkier TJ Wrangler Technical Forum 17 09-11-2003 06:58 PM
