Gas welder tip question - JeepForum.com
post #1 of 7 Old 08-10-2011, 07:00 PM Thread Starter
TheNewbie
I also posted ths in the fab section. But I really need an answer tonight and I know a lot of you guys weld.
I was borrowing a $3000 Lincoln welder and had to change a tip out (just the copper part with the small hole that the wire feeds through). It sheered off when I was screwing it in and the bottom half is stuck in there still.
I tried to drill a small hole and use an easy out to get the tip out, but the drill bit broke off in there too. I don't know much about how these go together or how the gas flows. Can I remove the whole front part of the nozzle and replace it easilly?
I'm talking about the part that the tip scwers into, and the outter cover goes on to cover up the sides of the tip. Sorry I'm not trained in welding and I don't know the names of these parts. Buu I need to get it fixed first thing tomorrow morning.
What should I do?
I can screw the whole thing off easilly, but how does it connect to the lines for the gas and wire?
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #2 of 7 Old 08-10-2011, 07:36 PM
Missouribound
Wow....have you used a welder before? Those tips generally go in with just your fingers, and then a small twist with a pair of pliers to secure it. How in the hell did you break a bit in copper? Drilling a hole and an easy out would have been what I would done. Call a welding supply shop and see if they can help.
Missouribound is offline
post #3 of 7 Old 08-10-2011, 07:44 PM Thread Starter
TheNewbie
To make a long story short... my brother is a dumb *** and the bit was a crappy one from harbor Freight.
post #4 of 7 Old 08-10-2011, 09:01 PM
dodger889
Wrong one for the machine. But you might have to replace the head of the welder to fix or take it in to a welding supply shop. to get it fixed.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #5 of 7 Old 08-10-2011, 11:07 PM
Hghgrad
The head is a separate piece...which should be stocked at any welding supply shop worth a damn. Probably going to cost you some money...
You can probably take it off yourself and see if you can get the broken bit out before you go that route though.
FYI...the tips sold at harbor freight don't fit a Lincoln. I believe they are interchangeable with miller and Hobart though.
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline
post #6 of 7 Old 08-10-2011, 11:14 PM
Hghgrad
Pretty simple...
Hghgrad is offline
post #7 of 7 Old 08-11-2011, 11:16 AM
92 Green YJ
92 Green YJ's Avatar
yeah the Miller gun comes apart with just one screw in the handle as I recall. only opened mine once and I forget now why I even did that. As stated, you don't need to slam those tips in there. just finger tight with a 1/4 turn extra will do just fine.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
arc welder mylightsrsquare YJ Wrangler Technical Forum 26 11-09-2010 07:25 AM
Welder Question spawnofsatan YJ Wrangler Technical Forum 14 12-15-2009 08:06 AM
welder question wanabejeeper YJ Wrangler Technical Forum 15 10-01-2009 05:52 AM
another welder question (opinions) johnroot01 YJ Wrangler Technical Forum 4 09-30-2009 02:41 PM
Just got a welder! ufatbastehd YJ Wrangler Technical Forum 7 05-05-2008 06:44 AM
