Gas Tank Skid Plate - JeepForum.com
post #1 of 17 Old 08-04-2010, 02:22 PM Thread Starter
19OlllllllO41
19OlllllllO41's Avatar
Gas Tank Skid Plate
I have searched the forum but have come up with very little...
Who makes a good skid plate for a YJ gas tank? Basically the only ones I have seen are Warn's and Kilby's. Most mfg's seem to only make them for TJ's. Please let me know what you have or recommend!
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #2 of 17 Old 08-04-2010, 03:03 PM
sebastian22
I have a Warn thatI got a good deal on at a Jeep show. Its an excellent product but a bit pricey. I recommend it.
95 Black YJ
sebastian22 is offline
post #3 of 17 Old 08-04-2010, 03:39 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Warrior products. I used one in my write-up on my '91 YJ.
http://www.jeepforum.com/forum/f12/h...emoval-981049/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 17 Old 08-04-2010, 04:03 PM
cubewhiz
Here's what I found:
Warrior Products - 12 ga (~1/8") - $170 (Qtec)
Tomken - 1/8" - $190 (Qtec)
Rugged Ridge - 3/16" - $250 (Qtec)
Kilby - 3/16" - $250 (Kilby Enterprises)
Warn - 3/16" - $284 (Qtec)
The Warrior and Tomken are approximately the same thickness, while the RR, Kilby, and Warn are about 50% thicker (are are priced accordingly!)
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #5 of 17 Old 08-04-2010, 04:17 PM Thread Starter
19OlllllllO41
Excellent, thanks guys. I had seen the warrior skid before but wasn't sure that it would really be an "upgrade" over the factory skid... but thanks for the added info on it Max.
The Present:
'04 WJ
'46 CJ2A
The Past:
post #6 of 17 Old 08-04-2010, 07:23 PM
bluexj
I just got the Warrior and it seems to be pretty solid. I would say a definite upgrade over stock.
bluexj is offline
post #7 of 17 Old 08-04-2010, 08:20 PM
notmyj
if your looking for a new skid, then it probably means your looking to use it. The thin 1/8" stuff isn't gonna hold up very well if you drop your *** end on a rock, log, etc. If your looking to upgrade, then go with something in the 3/16" thickness. They will be able to hold the weight of the vehicle and take impacts much better than a thin 1/8". If you look around, you will see that most "serious" armor is gonna be 3/16" steel or 1/4" aluminum.
If you get a thinner material and bend, break, or puncture it, you just lost $180 that would could have gone towards a heavy skid that would not have failed. Ultimately it depends on what your use is. But if you want upgrade it, go 3/16". If you want to replace it, go 1/8".
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #8 of 17 Old 08-04-2010, 08:26 PM
jeepercreeper77
jeepercreeper77's Avatar
i saw a right up where a guy took another stock skid plate.cut the main part out and welded it to his original. quite thick and durable and cheap. just a thought.
90 wrangler,4.2l,1" MML,CRT HEI Dist.,34/34(interco) weber, hurst shftr,5spd,5" BDS lft,f-d30/r-8.8,5/8 lft booms,1" bl,tflex belly up,JB convs. SYE,gdyr mtr35s,hurc'ed,smit src frt bump,gen-r rear bump w/tire carrier,f&r tube fenders,psc knokrs,r gen-rgt ful conr gurds,duel bat.,BIC,m8000
jeepercreeper77 is offline
post #9 of 17 Old 08-04-2010, 09:15 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I got a Warn about 3 years ago. I've dropped it on many rocks since then, and all I've done is scratch the powder coat. Well worth the extra money.
I've got a whole bunch of stickers from all the crap I've bought over the years. And I'm thinking of covering the bottom of the skid with them. Then I'll do a write-up on which sticker holds up the best.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #10 of 17 Old 08-04-2010, 10:40 PM
Wrangler11
Wrangler11's Avatar
I'd spend the extra $70 and get a 3/16" skid. I'm not a fan of kilby and have not heard anything about Rugged Ridge. Does skid row make a gas tank skid?
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #11 of 17 Old 08-07-2010, 06:06 PM Thread Starter
19OlllllllO41
Thanks again for the replies, I do plan to go 3/16 for sure, so that kind of narrows down the choices. I have had numerous Kilby products in the past and have been very happy with them (aside from the powder coat on the latest bumper I got). I have never had any Warn armor, but it looks good and would do the job im sure. So it will prob come down to Warn and Kilby then as they are the front runners with 3/16 skids. Ill check into the Rugged Ridge a bit more too. I was orig kind of hoping to go aluminum, but no one seems to be makin any alum skids for YJ's. I PM Gerald at Savvy about it and he just said there were a few Savvy prototypes out there for YJ's, but it didn't seem as though one would come to production due to low demand....
The Present:
'04 WJ
'46 CJ2A
The Past:
post #12 of 17 Old 08-07-2010, 06:35 PM
jeepster93
jeepster93's Avatar
My 5 year old Kilby:
I have the tar out of it.
jeepster93 is offline
post #13 of 17 Old 08-07-2010, 08:42 PM Thread Starter
19OlllllllO41
very nice!! I had a Kilby skid on my CJ7 and it was great... I dont know why im over thinking this skid dilemma! Love Kilby, just had a bad exp. with my last bumper.... metal must have been rusty under powder coat and it just started bubbling everywhere (and the bumper was brand new, had sat in my basement in the box for like 6 months, never had been installed. So i ended up sanding it out and rattle canning it). I hope it was an isolated incident... my other 3 bumpers, tank skid, fairlead mount, and steering box skid have all been great though. Thanks for the pic and the suggestion.
The Present:
'04 WJ
'46 CJ2A
The Past:
post #14 of 17 Old 08-08-2010, 08:05 PM
Mr.B
Mr.B's Avatar
Do you have any clearance issues with your Ruffstuff 8.8 cover? Dan at Ruffstuff says the Kilby is a little bigger, and has some problems with his covers.
Ham license:
Everyone is Welcome
Mr.B is offline
post #15 of 17 Old 08-09-2010, 01:35 AM
MukYJ
I like my Kilby, it is really heavy duty. Had it for about two years, and it is scratched up pretty badly with a little surface rust at the back edge like jeepster93's, but it's still completely straight.
Unlike what it replaced:
~/Garth - 1993 Wrangler S 2.5
{ }|||||||{ } "MukYJ"
He's right, as soon as you remove the trackbar the fuel rail will arc on the battery, killing you and all the kittens in a ten mile radius.
MukYJ is offline
Do I need a gas tank skid plate? TyWebb04 TJ Wrangler Technical Forum 9 09-03-2009 01:00 PM
gas tank skid plate stu'sjeep TJ Wrangler Technical Forum 18 05-12-2008 04:21 PM
gas tank skid plate NPerry05X TJ Wrangler Technical Forum 3 10-30-2005 04:49 PM
TJ gas tank in a YJ skid plate?? David K. YJ Wrangler Technical Forum 0 05-11-2005 07:42 AM
Gas tank skid plate FastX YJ Wrangler Technical Forum 2 09-13-2002 06:52 AM
