Gas tank question - JeepForum.com
post #1 of 27 Old 03-21-2010, 01:12 PM Thread Starter
YJMonster
Gas tank question
My fuel sender has been giving me problems since iv had the jeep so i ordered a sender last year and havnt put it on....
Here is the problem, i ordered a sender for an 88 15gal tank with 6cyl carb motor, the sender that came was round. when i dropped the tank it had a square sender on it. I am wondering if this is the right tank for the jeep, i know its been replaced once but im not sure if the right one was put on the jeep or if it came from another jeep,.
2000 xj 4.5 Rubicon Express extreme duty(sold)
1988 yj 2.5 RC lift, 1/2 boom shackles- My baby
YJMonster is offline
post #2 of 27 Old 03-21-2010, 02:29 PM
I8AHUMR
If you're talking about the opening in the tank where the sender goes into then yes it is rectangular. At least mine is on my 93.
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #3 of 27 Old 03-21-2010, 03:20 PM Thread Starter
YJMonster
But you have a 4.0 fuel injected i believe, im not sure though, that the 4.2 15 gal has a round opening, if you have the rectangle opening on the 4.0 i would assume that i have the wrong tank.
post #4 of 27 Old 03-21-2010, 05:30 PM
I8AHUMR
Mine is rectangular. I wasn't sure about yours since you have the 4.2. That's why I said on my 93. I hope I haven't confused you more??
I8AHUMR is offline
post #5 of 27 Old 03-21-2010, 05:43 PM
linemen339
Yes it will be a rectangle one in a plastic tank. "87-90" are carb. The difference is the carb and injected pickups. The don't make one for the carb anymore. The fuel injected one has the pump on it.
linemen339 is offline
post #6 of 27 Old 03-21-2010, 10:50 PM Thread Starter
YJMonster
Now im confused, the replacement tanks that iv seen for my year all have round holes for the sender, even the OEM style and i cant find a rectangle sender for my year, i saw some cheap tanks on ebay so i might just get one.
post #7 of 27 Old 03-22-2010, 06:16 AM
linemen339
They don not make a rectangle sender for the 87 to 90 YJ's anymore. You have to get one without the pump for the 91 to 97 and add the piece that is missing where the pump goes. Is this the tank you have? That is what I had to do.
post #8 of 27 Old 03-22-2010, 08:54 AM
wanabejeeper
1987 YJ Wrangler
The square opeinging is for the 20 gallon tank. here is the correct sender from Qtec
Original Replacement Parts 53003341X - Fuel Sending Unit 20 Gallon for 87-90 Jeep® Wrangler YJ - Quadratec
wanabejeeper is offline
post #9 of 27 Old 03-22-2010, 11:28 AM Thread Starter
YJMonster
my tank only holds about 15 gal
post #10 of 27 Old 03-22-2010, 11:35 AM
wanabejeeper
1987 YJ Wrangler
Cant really reply to that.... My tank looks similar to the one in the picture. Its on the ground behind my jeep right now. I ordered the square sender as per the link I posted after talking with the Qtec guys. It should be here in a day or two and I'll let you know if it fits.
I'll add a pic of my tank in a few
post #11 of 27 Old 03-22-2010, 11:37 AM Thread Starter
YJMonster
Is your tank 20 or 15 gal
post #12 of 27 Old 03-22-2010, 11:38 AM Thread Starter
YJMonster
nvm saw your post
post #13 of 27 Old 03-22-2010, 11:43 AM Thread Starter
YJMonster
now im wondering that if i buy a 15 gal tank will it mount right up or do i need to modify the skid or something
post #14 of 27 Old 03-22-2010, 11:47 AM Thread Starter
YJMonster
And without removing the tank is there a sure way to identify if it is the larger or smaller one.
post #15 of 27 Old 03-22-2010, 12:08 PM
wanabejeeper
1987 YJ Wrangler
guess what just showed up at my door? Re-reading your post... you have a square opening tank. Yes it is a stock 20 gallon tank. it needs the sender that I linked up in an earlier post.
CO2 tank question 10 or 15lb tank? FritzTJ TJ Wrangler Technical Forum 6 06-05-2009 10:36 AM
gas tank question strykermp5 JK Wrangler Technical Forum 4 02-20-2007 09:46 AM
Gas tank question.... bokey YJ Wrangler Technical Forum 10 07-17-2006 02:40 AM
Gas tank question Joey791 TJ Wrangler Technical Forum 6 12-02-2003 07:57 AM
Question about gas tank Bob J TJ Wrangler Technical Forum 0 06-18-2002 06:24 AM
