gas tank issues yj - JeepForum.com
post #1 of 31 Old 12-14-2011, 10:03 AM Thread Starter
JUNKYARDDOG01
gas tank issues yj
Hello all,
Wanted to pick your brain on my 1994 wrangler...
someone drilled a hole in my tank, to steal the fuel. my question is what other jeep if any can i take the tank from at the junkyard??
JUNKYARDDOG01 is offline
post #2 of 31 Old 12-14-2011, 10:11 AM
Louie4
Unless you find another YJ, I'd buy a new one. Well I'd actually consider a fuel cell first but that's me.
Of course, you can get creative and fabricate something to work with your YJ if you find something similar at a junk yard.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 31 Old 12-14-2011, 10:43 AM
jbolty
jbolty's Avatar
Unless the hole is huge you might try putting in a bolt and nut with rubber washers.
jbolty is offline
post #4 of 31 Old 12-14-2011, 11:07 AM
Louie4
Good point. I don't see thieves using a large drill bit to steal gas. Sucks they stole the gas and messed up the tank.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 31 Old 12-14-2011, 11:41 AM
Spuznick242
Is that what this world is coming to? Causing a few hundred bucks worth of damage (cost of a new plastic tank) for under $60 of gas? Come on.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #6 of 31 Old 12-14-2011, 11:58 AM
jbolty
jbolty's Avatar
Where have you been? Thieves have been doing thousands in damage to wires and a/c systems all over the country to grab $20 in scrap copper.
jbolty is offline
post #7 of 31 Old 12-14-2011, 03:11 PM
pasinbuy
No crap. Can you believe it. I had a renter and when he left not only did he trash the house, but also gutted the AC unit, and pulled all copper tubing for the gas lines. What a POS, and the courts let him off with a slap on the wrist.
pasinbuy is offline
post #8 of 31 Old 12-14-2011, 08:48 PM Thread Starter
JUNKYARDDOG01
Yea this is really annoying and trying to do this on a budget is not easy. no luck so far on the replacemet tank...dealer wants 700.00.
im thinking about going with the bolt idea...i still would have to drop the tank correct...what type of rubber washer should i use that wont get deteriorated by the gasoline?
post #9 of 31 Old 12-14-2011, 08:49 PM Thread Starter
JUNKYARDDOG01
.....also is dropping the tank hard to do in my driveway or do i need special tools??
post #10 of 31 Old 12-14-2011, 09:29 PM
Mark05059
leave the dealer alone on jeeps... try autozone.. I got the tank and straps there for under 150 dollars..
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #11 of 31 Old 12-14-2011, 09:38 PM Thread Starter
JUNKYARDDOG01
wow!!! i will check it out thanks...any tips on the removal and replace??
post #12 of 31 Old 12-14-2011, 09:51 PM
dodger889
yes you can do it. 4 or 5 bolts on the back and 3 or 4 bolts in the front. remove the hoses fill and lines .
Where did the drill??
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #13 of 31 Old 12-15-2011, 06:42 PM Thread Starter
JUNKYARDDOG01
ok i finally dropped the tank in my driveway..not too bad but i did struggle a bit. found out its plastic, i cant spot weld it or plug the hole...now the hunt is on for a used tank and straps, i snapped off the bolt and nut. i'm thinking i should replace the fuel pump while the tank is down....is that hard to replace?? the filter or strainer at the bottom looked dirty.... where's the fuel filter on these yj's??
post #14 of 31 Old 12-15-2011, 06:54 PM
panaceabeachbum
plastic welder works well on poly if you know someone with one , sometimes they are on sale at harbor frieght
http://www.harborfreight.com/plastic...ure-96464.html
panaceabeachbum is offline
post #15 of 31 Old 12-16-2011, 06:54 AM
Que89YJ
http://www.jeepforum.com/forum/f12/b...cement-903082/
As far as the tank repair goes, there isn't any real good way to repair the poly tanks. There are more then enough threads here where people have tried everything and only been able to get a short time out of a repair. Aparently the poly material doesn't bond and makes it impossible to truely repair. Try car-parts.com, searchtempest.com (craigslist super search engine), and google Jeep used parts. there are a bunch of great Jeep scrap yards around central Florida. Also, try to PM Mean Max here on the forum. He owns a repair shop down by you and is a one stop shop for any knowledge of Jeeps and repair.
Que89YJ is offline
any common gas tank leak issues? bword YJ Wrangler Technical Forum 5 08-30-2010 07:58 AM
Mid gas tank skid install issues mountaineerjp TJ Wrangler Technical Forum 7 08-06-2009 08:05 PM
Gas Tank Issues cpundsack YJ Wrangler Technical Forum 4 05-23-2009 05:19 PM
help with gas tank issues s.c.i.e.n.c.e YJ Wrangler Technical Forum 3 06-01-2006 03:12 AM
Gas Tank Skid & Fuel Pump Issues? tw_jeep TJ Wrangler Technical Forum 12 01-12-2005 08:25 AM
