Gas Tank Hose/Nozzle Location - JeepForum.com
post #1 of 6 Old 08-10-2013, 07:54 AM Thread Starter
jrobwitt05
I had a gas tank leak and a hose break. I have not had a chance to take the tank down yet but can anyone confirm the location of this nozzle? I think it hooks up to the top of the tank going into the fuel sending unit but I'm not 100% sure.
Thanks for your help
jrobwitt05 is offline
post #2 of 6 Old 08-10-2013, 08:27 AM
jokerchief462
Rollover valve and it is located in the right rear corner of the tub. Remove the dust shield and look up in their. It sits in a clamp
In case if a rollover it keeps fuel from leaking. It is a two piece. One piece rubber one plastic.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 6 Old 08-11-2013, 12:24 PM
Hilblee
On mine, the two vent hoses off the right side of the tank connect to a hard line that connects to that valve. Had the same as you, this thing was hangin down and took me forever to figure out what it was and where it connected---ha
Hilblee is offline
post #4 of 6 Old 08-11-2013, 03:30 PM
booya1967
Turnover valve, located behind rear passenger wheel. inside tub. PIA to get to and fix
1990 YJ Red with Black Hard top, work in progress.......
2006 TJ Silver with Black soft top
booya1967 is offline
post #5 of 6 Old 08-12-2013, 07:07 AM Thread Starter
jrobwitt05
Thanks a lot for all the replies, I found where the valve connects under the dust shield. I believe I had a small gas leak, does anyone think it's possible this broken valve was the cause of the leak?
post #6 of 6 Old 08-12-2013, 07:34 AM
jokerchief462
Yes it will let fumes loose and will leak on the ground.
