Gas tank Fell off - JeepForum.com
post #1 of 14 Old 09-17-2012, 08:13 AM Thread Starter
jkoch8819
Gas tank Fell off
I have a 1993 YJ, with 4" lift, 6cyl, Auto.
Well while driving yesterday I heard a clunk and my Gas tank litterly dropped off, Tank is shot, skid plate is junk, The rear Cross member (where the bumperetts attach) actually snapped and that caused the tank to fall, it also ripped the bolts from the middle cross member where the tank attaches. My question is, is there a kit that replaces the Cross members? or just the replacement parts that 4wd has? I can assume Welding is needed... I am looking for a good fix on a tight budget....
All Jeeps are Jeeps, But built Jeeps are Real Jeeps... Round or Square
**The Only Thing Snow is good for is to check if the Jeep is Leaking**
jkoch8819 is offline
post #2 of 14 Old 09-17-2012, 08:18 AM
sdotcarter
Well I bet the most common way are the replacement parts from autorust.
http://www.quadratec.com/products/56011_9062_07.htm
sdotcarter is offline
post #3 of 14 Old 09-17-2012, 08:24 AM Thread Starter
jkoch8819
4wd is a little cheaper, I was hoping there was some other type of fix... that I am un aware of.
post #4 of 14 Old 09-17-2012, 08:36 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Like a fuel cell? Yes it's possible but you will still have to deal with the rust once the axles fall off.
Luck Favours The Prepared
Anticanman is offline
post #5 of 14 Old 09-17-2012, 09:00 AM Thread Starter
jkoch8819
So Basically my only option is get the replacement rails weld them on cut out rust and do it right the first time and don't look for a cheap fix that will cost me even more!!!
post #6 of 14 Old 09-17-2012, 09:06 AM
TA-YJ
If your rust is so bad that parts of your frame are falling off it needs to be addressed ASAP. Having something like that on the road is dangerous to everyone. First thing I would say to do is crawl under there and go over your frame with a screwdriver. If its as rusted out in other places as it was in the rear you might be better off just buying another frame and swapping everything over
1992 YJ 2.5L
Engine Mods:4.0L TB, Ford Design III 19lb Injectors, Firepower Ignition System, Ford TBird Electric Fan, Pacesetter Header, Magnaflow Cat, Dynomax Super Turbo Exhaust
Suspension Mods:BDS 2" Lift, M.O.R.E. 5/8" HD Shackles, 1" Brown Dog MML
Other:LED Tails and Herculined
TA-YJ is offline
post #7 of 14 Old 09-17-2012, 09:29 AM
Old4X
1990 CJ7
Rust is cancer. There is no quick, cheap, easy fix. It can be made whole and safe again, but will be expensive.
If you can't weld, it may be easier and less expensive in the long run to find a rust free frame and swap it in.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #8 of 14 Old 09-17-2012, 09:52 AM Thread Starter
jkoch8819
the rest of the frame is ok and been patched.... And doing a frame swap is above my Backyard Jeep skills.....
post #9 of 14 Old 09-17-2012, 11:00 AM
MLJeeper
MLJeeper's Avatar
If you got things like a gas tank falling off. I seriously doubt the rust on the rest of the frame is in check. Be on the safe side and do a thorough inspection. One serious law suit will screw your world up. Depending on condition, repairs a pretty simple if you can weld at all.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #10 of 14 Old 09-17-2012, 11:06 AM
ZeroGravity
You don't need to use a stock replacement, and piece of steel will do. I used the front bumper from a CJ for my rear crossmember.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #11 of 14 Old 09-17-2012, 11:16 AM Thread Starter
jkoch8819
ok never thought of that..... what about the one towards the front of gas tank?? any ideas?
And it is not falling apart... just normal rust on the rear rails.... that have been patched.....
post #12 of 14 Old 09-18-2012, 01:02 PM Thread Starter
jkoch8819
any one else has a idea or fix?
post #13 of 14 Old 09-18-2012, 09:27 PM
imstillatwork
no more ideas. those are your choices. get rid of the rust by cutting and welding plates in, or get rid of the rust by moving your jeep to a clean frame (or sell & buy a replacement jeep)
The idea here is get rid of the rust.
If there is enough rust ('normal' rust???) on the rear that the gas tank falls off, you're most likely going to loose a rear shock mount or shackle mount very soon. front shackle mounts might not be too far behind. Not a pretty sight on a highway.
imstillatwork is offline
post #14 of 14 Old 09-19-2012, 05:33 AM
ZeroGravity
Hey guys, gas tank straps are paper thin and my original gas tank skid was almost non existant when I upgraded. I had to replace my rear most frame rails and two rear most cross members because they were sheet metal and rusted out as well. Believe it or not, rest of the frame is pretty much perfect.
91 YJ
98 XJ
2 door love
gas tank , YJ
Fell off...what is this?! Shellb2414 YJ Wrangler Technical Forum 12 05-29-2012 07:52 AM
Fan and hub fell off.... imstillatwork YJ Wrangler Technical Forum 15 06-10-2011 07:54 PM
This just fell off...what is it? scottywags TJ Wrangler Technical Forum 6 04-24-2011 12:01 PM
I think I just fell in love JDON TJ Wrangler Technical Forum 19 07-28-2009 02:31 PM
bolt fell off thatdude421 TJ Wrangler Technical Forum 24 06-16-2006 01:32 PM
