gas tank capacity - JeepForum.com
post #1 of 12 Old 10-10-2012, 07:58 PM Thread Starter
91killanotch
gas tank capacity
hey jsut wondering if anyone can tell me the size ( capacity ) of the gas tank in my jeep. its a 91 YJ 4.0L 5SPD. believe it or not i have searched for a bit and actualyl cant find the capacity, any help would be great.
91killanotch is offline
post #2 of 12 Old 10-10-2012, 08:01 PM
andygio71
I believe they came in 20 and 15 gallon versions for yj's in general, you likely have a 20 seeing as you've got the 4.0. Run it down to 1/8th tank or so and then top it off; if you're at or over 15 gallons for that fill up, you've got the 20
Edit: also, it's the same tank either way, the 15 just has a longer filler neck so you can't get all 20 in there. It was just a way to get people to pay more without costing the company much. This can be modified if you've got the 15, there are many write ups on it
andygio71 is offline
post #3 of 12 Old 10-10-2012, 08:04 PM Thread Starter
91killanotch
thas the problem i dont know where empty is fuel gauge no longer works, so im trying to figure out how much is in there at certain km intervals
post #4 of 12 Old 10-10-2012, 08:14 PM
andygio71
Mine doesn't work either, this is what I did: topped it off and ran it assuming 10mpg (I've got a carbed 4.2, you may do better depending on mods). After 140 miles or so, so using roughly 14 gallons, I filled it up. I went that distance because if I had the 15, I wouldn't want to get too close to running out. When I filled it I put in just over 15 gallons (looking back i realized i had it idling a lot during that week which explains the milage, i get 12mpg now) the there was no way I didn't have the 20 gallon tank. So now I just assume 10mpg and fill up at 170-180 miles. Hope that helps
post #5 of 12 Old 10-10-2012, 08:16 PM Thread Starter
91killanotch
i was thinking of doing the same kind of thing and jsut calculating it that way, was hoping there was just and easier way of figuriong out the size haha. thanks alot for your help, much appreciated.
post #6 of 12 Old 10-10-2012, 08:20 PM
mrmark
Actually, it's the vent tube and if you can get to it it's about 5 minutes to make it 20 gallon from 15. Pull the vent hose off the tank and then you will see a sleeve inside the tube, pull it out, it's about 7 or 8 " long. Then put the vent hose back on. You now will have a 20 gallon tank.
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #7 of 12 Old 10-10-2012, 08:42 PM
andygio71
no problem, that way that i found out was completely by accident, i didn't know about the 20 gallon at the time so i thought the gas station was screwing me over. the only other thing i just thought of is finding the options sheet for the jeep, the dealership can do it, i'd be surprised if it didnt mention the tank
oops, thanks for the correction, knew it was some kind of tube
post #8 of 12 Old 10-10-2012, 08:55 PM
Kamikaze
I have a 94 yj with the 4.0 and 20 gal tank and a 88 yj 2.5 with a 15 gal tank and the tanks are visually different in size.
Live Free, Laugh Loud and be Friendly.
Kamikaze is offline
post #9 of 12 Old 10-10-2012, 09:44 PM
fratis
fratis's Avatar
ive noted this but got tired of arguing with the masses about it. my 91 4.0 came with a 20 gal tank. people keep telling me and others to pull a hose out of it and i keep telling them it came as a 20.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #10 of 12 Old 10-10-2012, 09:52 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
The '87-'90 tanks (poly or steel) are completely different from the '91-'95 (poly for all) tanks.
ALL of the 15 & 20 gallon tanks used in the '91-'95 models are the same tanks & the 15 gallon versions can easily be converted to 20 gallons using the commonly known vent tube modification.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #11 of 12 Old 10-10-2012, 09:55 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
The stock vent tube sleeves are 10-1/2" for the 15 gallon tank, and 3-1/2" for the 20 gallon tank.
Max
Mean Max is offline
post #12 of 12 Old 10-10-2012, 10:32 PM
mrmark
Max
I just pulled it out never actually measured it...
mrmark is offline
