Gas tank access modification - JeepForum.com
post #1 of 15 Old 02-11-2007, 03:45 PM Thread Starter
Grape Ape
Web Wanker
Grape Ape's Avatar
I have been having trouble with my gas tank. I replaced a fuel pump a while back and it has leaked every time I run it. I have fought with it, I have taken the tank down 6 times, extended the hoses so that it will be easier to hook up still I get it all put back and it leaks fuel. I finally decided to mod my jeep to make it easier to work on the fuel pump and hoses without having to remove the tank.
I started by removing the gas tank. Once it was out I cut a section of the floor out approx 29" by 7". I made sure to leave the seat belt mount alone. I still put my seat in and haul people on occasion and did not want to mess it up in anyway so I cut behind its mount.
After that using 3" wide 1/8" thick flat steel I made a base to mount the cut out piece to. I drilled and tapped the pieces so that if necessary I can remove the bolts and slide the metal out giving me more room, without having to mess with nuts and washers on the bottom. I went to tractor supply to get my hardware and steel. The steel was expensive and all they had in 1/4" x 20 bolts/screws etc that were 3/4" long were grade 8 so I had to pay 3.88 for a lb of bolts instead of 1.98 for grade 2 but hey I was going to do it so I paid the price. Total material cost was approx $31.00. I made the pieces a hair shorter than the opening so they can be removed from on top
I then put the piece I cut out back in so I could drill and tap everything without worrying about drilling in to my tank. I found that the support piece welded to the bottom of the floor was in the way. I cut it off, yet left the bent part to help with strength.
I then put the piece I cut out back in so I could drill and tap everything without worrying about drilling in to my tank. This is also what it will look like when all is done.
I then took the cover back off and put the tank back. I hooked up all the electrical and hoses, filled her up and started it and found my leak. I was being way to careful before when tightening the hose clamps down and it was leaking around them. I cranked them down, leak stopped I am happy. Here is a pic of the top of the tank with the cover metal off. As I said before if I need more room to take the pump out I can remove both pieces of metal from above without any problems.
While I had the tank out I noticed my differential plug was leaking and figured I would check the level and add since I had the room. In the process of getting the plug out it broke and one part dropped in the diff other part out. So I had to remove the diff cover. I drained it and cleaned it, put the cover with a new gasket back on. I went to Advance, Autozone, O-reilly, and Napa, none carry the plug. I ended up using a 1" plug designed for a boat. I need my Jeep tomorrow morning and had to have it back together and running before I can swing by the dealer. I will replace it with the proper part but until then the boat plug works wonders.
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things, the people you meet and the books you read. Charles E. Jones
I think I'll add some memorable quotes. blah blah blah..... FPKites
Trying to understand some people, is like trying to pick up a turd by the clean side.
Grape Ape is offline
post #2 of 15 Old 02-11-2007, 04:14 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
tank access was a great idea... looks like you really thoght that out and did a great job.
as for your diff plug... i'd rethink that one. that would easily get caught on something while offroading... not to mention stupid vandels.....
Lookin Good!
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #3 of 15 Old 02-11-2007, 04:28 PM Thread Starter
Grape Ape
Web Wanker
Grape Ape's Avatar
I have to be in Oakridge TN tomorrow morning and that was all I could find the original diff plug was tore apart trying to get it out. I am going to either go to the dealer and get a plug, get a new cover with a screw in plug, or weld a large nut to the cover and put a bolt in it. That boat plug is only to hold fluid in for the next few days until I decide which route I am going to follow. I will probably get the correct plug tomorrow. But in a pinch the boat plug will get me down the road.
I am going to get me some rubber gasket material and make a gasket for the tank cover. I thought of silicone but it is way to cold out for it to work good, so I am going to wait until it gets warmer. I am just glad to have it stop leaking gas.
post #4 of 15 Old 02-11-2007, 05:28 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
i'd just go with a diff cover that has a thread in drain plug. if i still had mine laying around i'd send it to you for free but i tossed it when i threw out my dana 35.
post #5 of 15 Old 02-11-2007, 05:35 PM
72cj5er
72cj5er's Avatar
1972 CJ5
Great write up on the access, I can see that being very useful. as for the diff cover it begs the question, what lazy moron came up with that idea down at DC? I hope he was fired, they all leak. should be a recall LOL
72 CJ5 Renegade
86 MJ Pickup W/Tilt bed
94 YJ Wrangler
04 LJ Unlimited Wrangler
never far from a good trail
Growing old is mandatory; growing up is optional!!
72cj5er is offline
post #6 of 15 Old 02-11-2007, 05:36 PM
Weekender1969
Auto Zone sells a plug that would prolly work a little better. It is the same theory as that boat plug but you have to use a wrench to tighten it up so it would offer a better seal and is not so easy to be opened. They are made to replace stripped out oil pan drain holes and seem to hold up fairly well, and they got several sizes. They are not re-useable though. Once you open it back up that thing is supposed to be replaced.
Maybe this would help you out...
Weekender1969 is offline
post #7 of 15 Old 02-12-2007, 08:39 AM
pwoens
pwoens's Avatar
that is a smart idea....thanks!!
<>< Turn your face to the Son, and the shadows fall behind you
94 YJ 4.0L, BDS 4 1/2", 1" BL, 33 x 12.50, SYE & Tom Woods drive shaft, 8.8 w/lsd, Aussie Locker front, T & T Phantom tube fenders, Warn rock sliders custom cut, TJ rear flares and Fuel filler, Warn M8000, Custom front & rear bumpers w/swing out, bad apple diff guards, Dual 1400 amp Kinetic Energy batteries, HO alternator, 2 guage comp wires, VIAIR 450c, WRX seats, and way too much more to list. No end in sight!!
pwoens is offline
post #8 of 15 Old 02-13-2007, 05:38 AM
vadslram
The plugs are just plumbing plugs. Lowes, Home Despot, a good hardware store would have one you could use. It will have an external square drive, not an inset one.
vadslram is offline
post #9 of 15 Old 02-13-2007, 05:48 AM
EABiker
That's funny, I had to do that last night to replace my pump! There was no way I was going to try to drop the 18 year old tank with a large snowstorm only hours away. I used the mighty Dremel tool and cutoff wheels, ( only 6 of them! ) , to cut my opening. I made mine around 8x10, just enough to get in there and get access to the lockring holding the pump in. I will soon be sporting a nice .090 aluminum access panel as soon as I fab one.
EABiker is offline
post #10 of 15 Old 02-13-2007, 07:42 AM Thread Starter
Grape Ape
Web Wanker
Grape Ape's Avatar
As they say necessity is the mother of invention.
That is the reason I thought this up, twice now I have had to throw a tarp down and then some cardboard, just to keep dry and keep the ground from freezing me as I dropped the tank in 10-12 inches of snow. Then put the tank back and fired up the jeep only to find the plug is bad or the thing is leaking and have to drop it again. This is the only route to go.
post #11 of 15 Old 06-04-2007, 08:54 PM
dmcanally
dmcanally's Avatar
2011 JK Wrangler
What kind of tubing can I use for the connections from the tank to the filler? The old ones got torn up a bit when removing the tank. Aside from that I think I've got everything covered...
Actually, I got the patch that said "Gas Tank" on it but turns out its for metal gas tanks. Will this work on my plastic one or do I need to go switch it out for plastic? Included are the epoxy, patch (nylon cloth), sand paper, and a brush.
Red Jeep Club # 383
, _____
/l
,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
dmcanally is offline
post #12 of 15 Old 06-04-2007, 09:02 PM Thread Starter
Grape Ape
Web Wanker
Grape Ape's Avatar
IIRC it is 3/8 fuel line. I think you actually posted this in the wrong thread you should have posted it in your gas tanks problem thread.
post #13 of 15 Old 02-21-2010, 09:35 AM
ZeroGravity
This is awesome!
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #14 of 15 Old 02-15-2011, 01:33 PM
snakeroo
Wow, this is brilliant. Looks like I have to replace my fuel pump. So, I may just try this technique to save me from having to drop the tank. But what about the sparks from the dremel cutting wheel???
Blue 1993 Wrangler YJ, 6cyl, 4.0L 5spd, 140K miles.
snakeroo is offline
post #15 of 15 Old 02-15-2011, 05:31 PM
roklok
This procedure should be a sticky.
1995 YJ, 4.0, 5 speed, hardtop, bone stock.
roklok is offline
YJ - 15 to 20 Gallon Tank Modification Moxley YJ Wrangler Technical Forum 20 03-07-2014 11:21 PM
Gas tank access hole in tub.... Levinz11 YJ Wrangler Technical Forum 1 02-25-2009 10:42 AM
Jeep gas tank modification bearhunter YJ Wrangler Technical Forum 8 08-13-2008 04:37 PM
Fuel Tank Modification ? Six Shooter YJ Wrangler Technical Forum 3 04-27-2004 06:21 AM
Gas Tank Modification Question Six Shooter YJ Wrangler Technical Forum 6 04-23-2004 09:55 AM
