gas pedal sticking - JeepForum.com
post #1 of 11 Old 10-30-2009, 11:55 AM Thread Starter
8nine-sahara
gas pedal sticking
so everyonce in a while my gas pedal seems to want to play stupid.
ill be driving and then come to a red light and my pedal seems to be stuck and keeps the rpms pinned high. i have to basically kick on the throttle cable and pedal to bring in back to normal.
any reason why its doing this?
and is there any way to make it stop? thanks in advance,
Andrew
89 yj
06 lj
8nine-sahara is offline
post #2 of 11 Old 10-30-2009, 12:12 PM
squibload
Make sure that the very top of the gas pedal "leg" isn't getting hung up on the bottom of the AC/heater fan....if it is, remove an inch or so of the top with a Dremel/hacksaw/etc.
-Tom
1990 YJ Sahara
2004 KJ Sport
2006 Tahoe LT
squibload is offline
post #3 of 11 Old 10-30-2009, 01:35 PM Thread Starter
8nine-sahara
it's not hitting anything,
it's lik the cable itself gets stuck.
I have to basically push the cable in or punch the gas to get it to drop
89 yj
06 lj
post #4 of 11 Old 10-30-2009, 01:47 PM
MJMPC
Oil the cable . Or replace it .
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 11 Old 10-30-2009, 01:49 PM Thread Starter
8nine-sahara
like on the carb itself??
89 yj
06 lj
post #6 of 11 Old 10-30-2009, 01:52 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Look around the carb and make sure you don't have anything catching the throttle lever or cable end. If you can't find anything, your cable may be frayed inside. I bought a new one at Autozone for less than $14.00.
5.7YJ is offline
post #7 of 11 Old 10-30-2009, 07:39 PM Thread Starter
8nine-sahara
i dont think its the cable,
as its pretty much brand new. just put in the carb
its like theres too much slack in the cable
89 yj
06 lj
post #8 of 11 Old 10-31-2009, 07:15 AM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
How is the return spring on the carb? Does it have enough tension on it to close the throttle at idle?
5.7YJ is offline
post #9 of 11 Old 10-31-2009, 08:15 AM Thread Starter
8nine-sahara
I guess. but if I get a stronger spring,
would that help any?
89 yj
06 lj
post #10 of 11 Old 10-31-2009, 08:38 AM
vmann7
1987 YJ Wrangler
Yes, but it sounds like its binding somewhere, double check the carb linkage and make sure there is as little play as possible.
vmann7 is offline
post #11 of 11 Old 10-31-2009, 10:11 AM
AO1
My F-150 did that it was the cable freying in the cable covering. It finally snapped when I was in a tunnel I had to stop and pop the clutch in 4LO in order to get out at like 5 miles an hour. replace the cable.
I.Y.A.O.Y.A.S.
AO1 is offline
Gas Pedal sticking? greensaharatj TJ Wrangler Technical Forum 8 11-18-2009 04:17 PM
clutch pedal sticking yjman92 YJ Wrangler Technical Forum 4 11-08-2009 06:40 AM
Gas Pedal Sticking Joe1167 YJ Wrangler Technical Forum 6 03-12-2009 01:34 PM
Clutch pedal sticking tr6 YJ Wrangler Technical Forum 2 08-28-2006 02:07 PM
88 4cyl Gas Pedal Sticking DethKing YJ Wrangler Technical Forum 1 11-12-2004 02:39 PM
