Gas mileage so low? - JeepForum.com
post #1 of 36 Old 03-14-2013, 09:10 PM Thread Starter
Jakes93yj
Gas mileage so low?
I know my 93s yj 4.0 was going to be bad on gas for around town, but I wasn't expecting 10-12mpg on a 20 gallon tank. Is there something that could cause this? And how could a test the part if its bad or not? Also I'm goin to the beach in 2 weeks and will report back with the gas mileage after a lovely 200 mile drive. Thanks for reading.
Sent from my rooted Epic4g
Jakes93yj is offline
post #2 of 36 Old 03-14-2013, 09:20 PM
amiller
Seems like I'm getting the same mileage. The jeep wrangler has a drag coefficient worse than that of a brick. I have a YJ and a TJ. Neither one did I buy for economy. Just for my driving fun.
2005 Jeep TJ with some upgrades
amiller is offline
post #3 of 36 Old 03-14-2013, 09:28 PM Thread Starter
Jakes93yj
Re: Gas mileage so low?
Ok. I thought I was the only one getting crap for gas, its expensive for these things to be a DD. Is yours lifted or anything? Mines completely stock(for now). I plan on going with a 4" RC lift and 33x12.50 bfg km2's or nitto mud terrains. So there goes more gas.
post #4 of 36 Old 03-15-2013, 08:11 AM
pete1991YJ
Tune-up time, in a big way. You should be able to get 17-18 MPG's with a mostly stock 4.0. I'm getting ~20 with the 4-banger. The O2 sensor is the #1 thing that determines your fuel mileage. Also check if the exhaust manifold is tightly bolted onto the head -- leaks here can fool the O2 sensor. Check for vacuum leaks by spraying some carbcleaner around the ends of all the vacuum hoses. Especially the fuel pressure regulator. Make sure the return lines aren't pinched at the tank. Check the air filter.
All these things affect the MPG's.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #5 of 36 Old 03-15-2013, 08:32 AM
RowJ
19-20 w/ a 4 cyl....maybe. I have no experience with them.
But 17-18 mph on a 4.0L is VERY rare...... and if honest test, with no tail wind and not going downhill all the way ....
I suspect never!
My best ever, with a new engine and across level west Texas for 150 miles, was 15.1 mpg. And that was at 55 mph.
RJ
RowJ is offline
post #6 of 36 Old 03-15-2013, 08:45 AM
wanabejeeper
1987 YJ Wrangler
I'm getting about 10 on a recently rebuilt 4.2/ Weber, nuttered, Team Roush and MSD 6 ignition. I'm using a fuel/air gauge so I'm pretty sure my mix is correct but I still have to take it to inspection to be sure. I'm leaning more towards my 3.07 gears and 31" tires as the problem. I have a 4 wire A/F gauge I'm going to install in a few weeks. I'm also going to confirm my engine RPM's and install a tach that will work with my ignition. I'm planning a frame off next year and if I feel the gears are the problem I'll do either an 8.8 or a D44 rear with 3.55's and regear my D30. Having said that I never expected my mileage to be much better than 15 anyway.
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #7 of 36 Old 03-15-2013, 09:05 AM
tdewit
My wife's '95 4 banger, between 18 and 20 MPG, depends on the day. Dead stock.
My '91 4.0, between 14 and 15 MPG. 31's with a 1" BL
tdewit is offline
post #8 of 36 Old 03-15-2013, 03:05 PM
ryanderson
I went from 10 to 13 mpg just by changing oil and diff. oil
ryanderson is offline
post #9 of 36 Old 03-15-2013, 05:12 PM
Chrisnvegas
Chrisnvegas's Avatar
I recently filled the tank (20 gal) drove 110 miles. Have 3/4 left. although it seems to use the bottom half faster than the top half.
I have checked my MPG in the past. As bad as 12 at high highway speeds (75+) or as high as 17 or 18 (under 65)
I have an automatic so at 70 I'm pushing almost three grand.
"Auto racing began 5 minutes after the second car was built."
Henry Ford
Chrisnvegas is offline
post #10 of 36 Old 03-15-2013, 05:41 PM
blown50
1987 YJ Wrangler
17 -23 mpg 4.7 stroker 3:08 gears 5 speed 30 inch radial tires, hard top with air and it will hit triple digit mph
blown50 is offline
post #11 of 36 Old 03-15-2013, 06:30 PM
Chrisnvegas
We don't want to hear about it.
Henry Ford
post #12 of 36 Old 03-15-2013, 07:10 PM
pete1991YJ
Seriously tho, I think the OP's gas mileage is too low even for a big 6-cylinder and a lead foot. There are other guys on here getting much better than that with the exact same setup.
post #13 of 36 Old 03-15-2013, 08:34 PM Thread Starter
Jakes93yj
Seriously, its not lifted(yet) it has stock motor, stock tow package, 30 in radial bfg at's, its a hard top, everything is stock
post #14 of 36 Old 03-15-2013, 09:37 PM
pete1991YJ
That's exactly what I mean, you should be getting at least 15 MPG's if not more.
post #15 of 36 Old 03-15-2013, 10:19 PM
yellow2kgt
Do you have an automatic or 5 speed? That sounds about average for the 3 speed auto. No overdrive really hurts the mpg. The best I ever got from my auto YJ was 14 mpg when stock
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
