Gas mileage queston - '90 YJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Gas mileage queston - '90 YJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!TJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 09-21-2011, 02:44 PM   #1
syphonation
1988 FSJ Wagoneer
I recently bought a 1990 YJ and the gas gauge is broken. I haven't had much time to diagnose the cause, but I was hoping someone running a similar setup could give me an idea of what kind of mileage I should be getting. I'm trying to avoid completely filling the tank as the filler hose leaks when the tank is topped off. Anyhow, here's the rundown:
1990 YJ
2.5 liter engine
5 speed
4.88 gears
35" MT tires
Thanks,
Jimmy
syphonation is offline   Reply With Quote Quick reply to this message
Unread 09-21-2011, 02:56 PM   #2
Andywear
guessing bump
12mpg
Used to have a good sig but Mod threated to ban me...
[I]Errrrrrr[/I], Will complain else where - &y
Andywear is offline   Reply With Quote Quick reply to this message
Unread 09-21-2011, 03:17 PM   #3
dillonjm
30mm@70/sec
dillonjm's Avatar
That's probably pretty close, I'd say 13-14 most likely. Maybe as high as 15-16 depending on driving style, but that's probably tops.
03 Rubicon (Weekend Toy) Build thread
11 Ram 2500 - H&S tuned 6.7 Cummins (DD/Tow Rig)
05 Liberty Limited (Wife's): Minor mods, OME/JBA Suspension, 245 70/17 Duratracs
dillonjm is offline   Reply With Quote Quick reply to this message
Unread 09-21-2011, 03:22 PM   #4
syphonation
1988 FSJ Wagoneer
Originally Posted by Andywear View Post
guessing bump
12mpg
Thanks guys. That's good news considering my last ride got 8.
