Gas Leak!!! Argh!! Help! - JeepForum.com
post #1 of 4 Old 07-31-2002, 07:49 PM Thread Starter
evilpsych
evilpsych's Avatar
well wonderful.. i order my parts, and then this happens. a hose going between the gas tank and the filter ruptured while i was out running errands.. i was able to limp home, but i lost about 10 gallons of gas for a 2 mile trip. other bad news is that i have to drop the tank to fix it
has anyone else done this before? how difficult is it on the YJ? I believe all i have to do is disconnect the fill hoses, the hoses going to the engine, and the 10 or so nuts holding the skidplate/gas tank on and drop it, then replace the hoses, jack back up into position, and go..
any tips or hints would be great. I'm going to siphon out as much gas as possible before hand though.
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 4 Old 07-31-2002, 07:58 PM
RCHavok797
RCHavok797's Avatar
That sucks man. Just got done changing the fuel filter on mine and while removing it one of the small lines connecting it popped. The stupid thing was all cracked.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #3 of 4 Old 08-01-2002, 01:31 PM
RichardL
Tips:
Get a friend to help you drop the tank, and a floor jack makes it much easier.
RichardL is offline
post #4 of 4 Old 08-01-2002, 01:54 PM
Bob J
Bob J's Avatar
1984
with the tank near empty and a good floor jack, this is a moderate one person job
it's a pain, but it's another one of those jobs where patience pays off.
one tip; (the only problem I encountered dropping the tank on my YJ)
when putting the tank back up, be careful not to push any of the bolts sticking out of the rear crossmember up into it.
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
Ok now WHAT do these plugs go to!!! ARgh Johnyakimo1855 YJ Wrangler Technical Forum 2 01-01-2010 06:35 PM
argh... BoHeck TJ Wrangler Technical Forum 13 05-03-2007 05:27 PM
Argh!!!! dr hook TJ Wrangler Technical Forum 11 12-22-2006 08:30 AM
Argh, regular LJ? Deezul TJ Wrangler Technical Forum 13 12-22-2005 06:30 AM
Radiator ARGH! Deezul TJ Wrangler Technical Forum 21 11-29-2005 08:45 AM
