gas gauge help!!!!!!!! - Page 2 - JeepForum.com
post #16 of 20 Old 10-19-2007, 04:00 AM
DaSham58
DaSham58's Avatar
1987 YJ Wrangler
Mine was bouncing around, And when I filled the tank up the gauge would read way past full So I replaced the sending unit did not fix it I went and replaced all the gauges with AutoMeter Gauges still bounced around and was reading way past full when I filled up. My problem was right under the dash right above the emergency brake there is a plug where the rear wirering harness with the fuel sending unit wires is connects to the front I unpluged it and used some electric cleaner and grease and plugged it all up and now all is good! No more bouncing and reads acurate now. Hope this helpes!
Poor People Have Poor Ways!
DaSham58 is offline
post #17 of 20 Old 10-19-2007, 08:32 AM
amg61
amg61's Avatar
can you be more specific about that harness/plug, what it looks like, or do you have a picture? this would be an easy fix if it were the cause, so i just want to make sure i'm looking at the correct plug/harness. thanks.
TFI/GM HEI Hybrid, MC2100, M.O.R.E. greasable shackles, TJ flares, AtoZ Fab Rocker panel, 31" BFG AT; Getting there.....
amg61 is offline
post #18 of 20 Old 10-19-2007, 11:31 AM
DaSham58
DaSham58's Avatar
1987 YJ Wrangler
It would be hard to get a picture of it. Pretty close under there just look right above your emergency brake that is where it is.I will look at mine and see if I can get a pic of it .
DaSham58 is offline
post #19 of 20 Old 10-19-2007, 11:56 AM
DaSham58
DaSham58's Avatar
1987 YJ Wrangler
Ok it wasnt as bad as I thought it would be here is the picture of the plug. Unplug it and get some spray electrical cleaner and some electrical grease that solved my problem!
DaSham58 is offline
post #20 of 20 Old 10-19-2007, 12:03 PM
amg61
amg61's Avatar
awesome pic!!! thanks!!! will take a look later.
amg61 is offline
reading 0 on gauge volt battery gauge alecmcmahon TJ Wrangler Technical Forum 13 04-19-2009 03:43 PM
98 Sahara no start no fuel gauge no volt gauge.Cps already changed... CrazyRobCustoms TJ Wrangler Technical Forum 5 03-25-2009 11:52 AM
Volt gauge problem, pegs the gauge 472cid TJ Wrangler Technical Forum 4 01-05-2009 06:52 PM
vacuum gauge in place of 4 wheel gauge Think YJ Wrangler Technical Forum 3 02-06-2007 11:15 AM
Oil Pressure Gauge and Fuel Gauge problems phattdraggon YJ Wrangler Technical Forum 5 05-11-2004 03:12 PM
