gas gauge help!!!!!!!! - JeepForum.com
post #1 of 20 Old 10-16-2007, 07:11 PM Thread Starter
bill bangler
my gas gauge is stuck on e and i Know it has gas. What could it be
bill bangler is offline
post #2 of 20 Old 10-16-2007, 07:28 PM
jeepwrangler123
my oil pressure, and voltage gauge do that all the time i just tap on them, or hit them till they feel like working again lol. not really sure what causes it though
jeepwrangler123 is offline
post #3 of 20 Old 10-17-2007, 06:35 AM
The Rat
My gas gauge is stuck on whatever I move it to, which is full, that way people think my Jeep runs on magic and never needs refilling.
Actually, I just gave up on fixing it, I fill up every 250-275 miles.
OH WAIT. WHAT?
The Rat is offline
post #4 of 20 Old 10-17-2007, 07:35 AM
jaw41272
jaw41272's Avatar
It could be the sending unit in the tank, the guage itself, or just a bad ground
91 Sahara 4.0l Operation Welcome Home Parade Veh #69
PARADE JEEP MEMBER #1Auto posi-lok equipped, 4" susp. lift
K&N Drop in and loaded with battle scars
FOR SALE 2005 PT CRUISER CONVERTIBLE
2005 Suzuki DRZ400S For SALE
jaw41272 is offline
post #5 of 20 Old 10-17-2007, 07:56 AM
PanthrosRevenge
PanthrosRevenge's Avatar
Watch out for the oil pressure sending unit. Mine ended up blowing out 4/5 of my oil on the freeway.
PanthrosRevenge is offline
post #6 of 20 Old 10-17-2007, 08:08 AM
EABiker
Does the guage go to empty when the key is turned off?? If not, the guage is bad since it requires a voltage to go to full, and the voltage is not there when the key is off.
EABiker is offline
post #7 of 20 Old 10-17-2007, 08:29 AM Thread Starter
bill bangler
any one know where the grounds are for it its a 94 4 cyl and it reads empty all the time
post #8 of 20 Old 10-17-2007, 09:54 AM
The Rat
This info isn't accurate, as my gauge always reads full (or wherever I put the needle) even when the Jeep is off.
OH WAIT. WHAT?
The Rat is offline
post #9 of 20 Old 10-17-2007, 10:08 AM
whyjay
Mine bounce all over when I hit a bump but it seems to bother the passenger more than me. I just fill up when it starts bouncing oround empty. I also keep an eye on the milage.
whyjay is offline
post #10 of 20 Old 10-17-2007, 02:20 PM
NJeepyj91
I don't want to gloat but I am now getting an accurate reading for the 1st time in 15 years. Got rid of that fubarred OEM guage cluster. I am very happy now.
NJeepyj91 is offline
post #11 of 20 Old 10-17-2007, 06:26 PM
That1guy
That1guy's Avatar
2007 WK
It could be a bad float, the float might be stuck, bad sending unit, wires might be bad, and/or the gauge is bad.
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline
post #12 of 20 Old 10-17-2007, 07:14 PM
NJeepyj91
I have been putting up with that advice and I respect your post. I changed the pump and the sender. No mean feat with that god awful skid mount.
I cleaned the ribbon so many times.
I got sick of it. No big deal. I replaced all of the gauges.
The only reliable gauges on a yj are the tach and Mph.
Worst design ever...ever.
After replacement. Everything works fine.
post #13 of 20 Old 10-17-2007, 08:17 PM
Dna5150
Our's does the same thing, but only when we put gas into it when it's nearly empty or is empty. We just swirve back and forth down the road a few times and the floater gets unstuck and starts working again.
Dna5150 is offline
post #14 of 20 Old 10-17-2007, 09:35 PM
That1guy
That1guy's Avatar
2007 WK
Are you talking about my post? I just listed some possible problems.
That1guy is offline
post #15 of 20 Old 10-18-2007, 01:57 AM
NJeepyj91
Not specifically. You did list the possible probs and I agree with you.
Been using the trip odo for 15 years. Not a bad solution but my heap is a DD and used under various conditions. I just wanted to solve the issue of no volts, maxxed out oil pressure, iffy temps and no gas indicator.
To tell the truth, I have been on the side of the road twice because I forgot to reset the trip odom. Never again.
reading 0 on gauge volt battery gauge alecmcmahon TJ Wrangler Technical Forum 13 04-19-2009 04:43 PM
98 Sahara no start no fuel gauge no volt gauge.Cps already changed... CrazyRobCustoms TJ Wrangler Technical Forum 5 03-25-2009 12:52 PM
Volt gauge problem, pegs the gauge 472cid TJ Wrangler Technical Forum 4 01-05-2009 07:52 PM
vacuum gauge in place of 4 wheel gauge Think YJ Wrangler Technical Forum 3 02-06-2007 12:15 PM
Oil Pressure Gauge and Fuel Gauge problems phattdraggon YJ Wrangler Technical Forum 5 05-11-2004 04:12 PM
