Gas filler hose - JeepForum.com
post #1 of 16 Old 08-05-2011, 06:59 PM Thread Starter
Toyjunkie
Gas filler hose
1993 has bad fill hose, local dealer says not made anymore, can't tell me if any other hose made on this planet will fit. What's the word boys and girls, what will work for this? I know I can take what left of it to local auto part store and get blank stare from parts man, was just hoping to at least have a direction to go.
By the way went to local auction out bid every other idiot for a Wrangler. So far Replaced, front and rear ends (rear was locked up) front was just welded to the springs and Ubolts ???. both drive shafts were junk. Front springs, steering column, engine and dash wiring harnesses (should have seen that rats nest) Just wanted to let you all know I'm not afraid of a challenge!
Toyjunkie is offline
post #2 of 16 Old 08-05-2011, 07:26 PM
SquidsYJ
Hey, welcome to JF.
Have you tried Morris 4x4. discount jeep parts, or Quadratec? Between those three I usually find any parts I'm looking for.
SquidsYJ is offline
post #3 of 16 Old 08-05-2011, 07:31 PM
timatoe
timatoe's Avatar
http://www.mtscompany.com/
timatoe is offline
post #4 of 16 Old 08-05-2011, 07:37 PM
Skydmark1
Sounds like a good time to make the TJ filler mod!
-2013 JKU Sport, bone stock, Auto with 3.73's
-1998 ZJ Laredo, 4.0 42RE Selec-Track, 30" M/T tires
Skydmark1 is offline
post #5 of 16 Old 08-05-2011, 08:34 PM
superj
/\ preach on brother
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #6 of 16 Old 08-05-2011, 08:45 PM
oldtime_ironman
Believe it or not my local NAPA auto parts can find stuff that the dealer doesn't even know about. Might want to look into them.
Congrats on the wrangler and welcome !
oldtime_ironman is offline
post #7 of 16 Old 08-06-2011, 12:54 AM
wendell
1987 YJ Wrangler
Collins brothers has a jeep junkyard, I'm sure they would have it, but used.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #8 of 16 Old 08-06-2011, 08:21 AM
Dewster196
Check with Davey.
http://http://www.daveysjeeps.com/specials.html
A Nation of Sheep Breeds a Government of Wolves!
Dewster196 is offline
post #9 of 16 Old 08-06-2011, 11:22 AM
nathanninja
I bought one of these to replace my cracked one, a little pricey for a piece of rubber but it does the trick
http://www.quadratec.com/products/51308_06.htm
EDIT: I found it here for a few bucks cheaper
http://www.jeep4x4center.com/fuel-fi...-52040079.html
nathanninja is offline
post #10 of 16 Old 08-08-2011, 11:17 AM Thread Starter
Toyjunkie
Cool thanks for the leads. also is there a nuetral switch on these things? After changing both harneses jeep won't start with key but can jump across starter and it starts????
post #11 of 16 Old 08-08-2011, 11:58 AM
Buddha
Originally Posted by timatoe View Post
^^ X2 Got both filler and vent hose for my 93 from these guys.
I have read hundreds, if not thousands, of threads on here and it's amazing the percentage of problems that wind up being caused by something the owner has accidentally done to the Jeep while working on it.
Moral to the story: If you moved it, unscrewed it, unbolted it, hammered on it, wiped it off, re-wired or replaced it - Check there first!
Buddha is offline
post #12 of 16 Old 08-08-2011, 01:57 PM Thread Starter
Toyjunkie
ordered from mts.com 26.00 for both fill and vent hose + 7.00 shipping. I think thats not bad, if it is don't tell me.
post #13 of 16 Old 08-08-2011, 02:36 PM
jbolty
jbolty's Avatar
Not a bad deal.
There are two problems with these hoses. The ends are not the same size and it make too sharp a bend to just curve it with normal hose and not have it kink.
When I replaced mine I used some rubber hose on each end and a 3/4 copper elbow in the middle. Later, I did the TJ side filler mod which makes the hoses a straight shot to the tank. I found some hose at ace hardware that was soft enough to fit on both ends with a little boiling water to help stretch it.
jbolty is offline
post #14 of 16 Old 08-08-2011, 03:22 PM
Buddha
Originally Posted by jbolty View Post
Not a bad deal.
The ones I got from MTS fit Jeep's sh*tty design perfectly. They have different sized ends and bend 90 degrees just like the are supposed to...
Buddha is offline
post #15 of 16 Old 08-08-2011, 04:50 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I agree. I use MTS for all of my fuel pump & fuel tank needs for whatever Jeep that comes in my shop that needs these items.
High quality products, low prices, great service. Thumbs up all around for www.mtscompany.com
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
gas filler hose tonylax48 YJ Wrangler Technical Forum 11 04-08-2011 08:34 PM
Fuel Filler hose caddyman YJ Wrangler Technical Forum 1 12-14-2010 01:17 PM
Gas filler hose Coldfever YJ Wrangler Technical Forum 13 02-24-2010 07:00 PM
Fuel filler hose jbolty YJ Wrangler Technical Forum 2 07-19-2009 01:25 PM
extending filler hose jeepin94 YJ Wrangler Technical Forum 7 04-24-2004 02:37 PM
